Thought of turbulence model used in automotive
I am working in an electric sport car company as a CFD engineer. My job is to analysis drag and lift of our car under different configurations. Currently, I am using OpenFOAM for this jobs. The numerical setup for the simulations are as follow: Turbulence model: k-OmegaSST Gradient scheme: cellLimited leastSquares 1 Divergence scheme (U): linearUpwind Divergence scheme (others): upwind Cell number: 40~60 millions Average y+: 20~30 We have recently consulted with a aerodynamic professor who has worked in the automotive industry for more than 30 years. He has some comments on my CFD settings. His first comment is to use k-Epsilon or SA model instead of K-Omega model. The second comment is y+ should be 1~5. These two suggestions seem to be counter-intuitive to me, especially the first one. In my understanding, k-Epsilon and SA are the worst turbulence model that would have been picked for vehicle simulation. They are well known for under predicting separation at the rear window which will result in under estimate drag and lift. The second comment is more of a practical reason rather than a technical one. It is almost impossible to achieve such small y+ in real car simulations. Could you guys give me comment on this topic whether you agree on the professor comment or not please? I am a bit confuse. Thank you very much Jason |
I think that try to evaluate the viscous drag by using the first cell at y+=20 is the main reason for the negative comments you received.
This way you have to work with wall-modelled BC.s, that is you are somehow already prescribing the drag as a BC instead of trying evaluating it by the solution. |
Thanks for your reply. If I am not getting you, you mean y+ 20 is too large to solve the boundary layer, right? If that is the case then I have another question. Is the wall shear stress or viscous drag important to a bluff body like a car? What is the typical viscous drag value? I have calculated the viscous drag of our car at 30m/s and the value is just less than 20N when using wall model. Is this value sounds reasonable?
Thanks very much for your advice Filippo. Is there any comment on the turbulence model or numerical scheme too?
Hi hokhay,
Your mesh size is too large and still you are not able to achieve the y+ values needed by the k-omega SST model (between 1 and 5). This means the viscous drag is not correctly predicted and may be the separation point also. If you wish to continue using this model then you will have to increase your mesh size, which will make your simulations more expensive. Using the k-epsilon model with wall functions you will get results of similar quality and you might get some margin to reduce the mesh size. PS: The SA model also requires wall y+ between 1 and 5. |
Thanks a lot for your reply, Ravindra. I also feel strange to I still cannot achieve smaller y+ with such mesh size. Some researchers can achieve y+<1 even with 20M cells on a DriVaer model at the same speed as mine. My first mesh is at 5×10-4m from the wall. If I goto y+=1, the first cell will be 5×10-5m which seems unreasonably small. This makes me confusing of the definition of y+. Actually the y+ various from 0.001 to 98 on the whole car and the average y+ is 19. In this case, should I say my case has a y+ of 19?
Regarding to the turbulence model, from your explanation, the k-Omega SST advantage of better separation prediction does not hold if y+>5? Will it still better then k-Epsilon when both using wall function at the buffer zone, y+=19? Thanks very much |
Hi hokhay,
I gather that you have maintained first cell height of 0.5 mm everywhere on the surface of your car and with that you are getting wall y+ in the range of 0.001 to 98. In that case, instead of talking about average y+, you should say that the velocity gradients and hence the friction force is correctly predicted in the regions where the y+ is less than 5 and incorrectly elsewhere. About the mesh, fine mesh is required only in the boundary layer and wake regions. Elsewhere the mesh can be coarse since the flow is essentially inviscid there. If you have already done this then you can increase surface mesh size in the regions where y+ is less than 1 and use higher first cell heights in these regions. This will be a very tedious and time consuming task. From an engineering perspective, I would suggest you to do the following. In your simulations with k-omega SST model, check the wall y+ values in the vicinity of the separation point. If y+ is below 5 for some distance ahead, at and after the separation point then you can safely say that the separation point and hence the total drag is predicted fairly accurately. If not then try to achieve y+ < 5 in that region. The total drag will still have some error due to wrong prediction of the skin friction drag but, as you correctly said in one of your previous posts, it does not contribute significantly to the total drag of a bluff body like a car. |
Hockhay,
Are you also considering the aspect ratio of your inflation layer (prism) cells ? You have to realise that by increasing their aspect ratio, you can decrease the number of cells in your model ! Obviously, the aspect ratio needs to be within acceptable limits and you need to investigate this a little more. My limited knowledge leads me to understand that the aspect ratio can be quite large as long as the flow is parallel to the long edge of the cell. Furthermore, increasing cell size sufficiently downstream and upstream from the area of interest also helps to reduce number of cells. This way, you can use the k-w SST solver with Y+ ~1 on a DrivAer model with less than 10M nodes. PS. If you want to use k-e turbulence model, then a Y+ from 60 and 300 is ideal. Regards |
Thanks for your reply Ravindra and Arnie. I got it now, so make sure y+<5 at critical region.
Arnie, the high aspect ratio and the small area are the main difficulties I am facing when making the boundary layer mesh. I am using SnappyHexMesh for meshing. I am only able to get a nice mesh for the first cell height of 0.1mm, equivalent to y+=8. Further reduce the height will result a collapse of the mesh because of bad mesh quality, otherwise I will need to reduce the mesh size further more. P.S. Which meshing software you guys use? |
Glad to know that I was able to help. Good luck for your project.
PS: I use ICEM CFD for meshing. It allows one to set different first cell heights of prism cells over different surfaces of the car. |
