Parallel iterative solver package for Windows system
Like Tree1Likes
  • 1 Post By ztdep
Old   November 28, 2017, 03:29
Default Parallel iterative solver package for Windows system
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear friends:
I am looking for a Parallel iterative solver package for Windows system written in fortran.
Could you please give me some suggestions.
Regards
ztdep is offline   Reply With Quote
Old   November 28, 2017, 13:00
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Most of the major packages are in C (PETSc and Hypre). LIS also is in C, but has the AMG coded in Fortran. Trilinos might even be in C++ (I don't know, but certainly it is not in Fortran).
The only package I know of being in Fortran is http://www.mld2p4.it/
But I suspect that the Windows support is near to 0. Not that it is impossible to make it work (gfortran is nowadays available in multiple flavors), but I suspect the dependencies to be more troublesome. Maybe someone else can help here.
sbaffini is offline   Reply With Quote
Old   November 28, 2017, 20:43
ztdep's Avatar
p ding
Thank you very much! let me try it.
sbaffini likes this.
Old   November 29, 2017, 03:19
sbaffini's Avatar
Paolo Lampitella
Let us know
Old   November 29, 2017, 06:55
Praveen. C
praveen is on a distinguished road
PETSc is written in C but can be called from a fortran code.
praveen is offline   Reply With Quote
Old   November 29, 2017, 07:57
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
What do you mean by parallel ? Are you referring to distribuited (MPI) or shared memory (OpenMP). Unless you have a cluster MPI won’t do much for you so I guess you are using a desktop system. If so, you can use GNU Fortran and install OpenMP. That is not very efficient because that will require installing Cygwin which is a Linux emulator. If you have a bigger budget then you can try intel Fortran which is a great compilers. The latter has a ice feature that parelizes section by itself with very good performance compared to OpenMP in GNU Fortran
juliom is offline   Reply With Quote
Old   November 30, 2017, 16:50
ztdep's Avatar
p ding
Let us know
I have tried several packages. Only Hypre can be compiled sucessfully in windows 7 systems with codeblock or vs2014.
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 15:44
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 08:05
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Navier-stokes equations and iterative solver?? wuliang Main CFD Forum 2 January 13, 2003 22:28
