residual convergence vs variable stabilization |
December 1, 2017, 16:32 |
Hello to you all,
In a couple of simulations I am running I have come into these situations: Case 1.- A simulation reaches the residuals limit established (1e-4), but the simulation was not stopped and the variable of interest (monitor point) is still changing with every iteration. Should I stop the simulation and trust the value at the iteration when the residual limit was reached? or should I keep on with the simulation till the variable value settles? Case 2.- A simulation never reaches the residuals limit established (1e-4), but the variable of interest (monitor point) after a certain number of iteration shows no significant change. Is this a reliable solution even though the residual limit was never reached? Case 3.- A simulation never reaches the residuals limit established (1e-4), and the residual plot shows some residuals are stuck around a certain value (for example 1e-3). Should I stop the simulation? Should I keep on and wait till the value of the variable of interest stabilizes (for example pressure)? I hope you can enlighten me about this situation. Thanks in advance. |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Foam::error::printStack after large bounding epsilon events | StoneCFD727 | OpenFOAM Running, Solving & CFD | 1 | January 1, 2018 17:04 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
