Analysis of two fluid cross flow heat exchanger.
Old   April 17, 2016, 02:52
Default Analysis of two fluid cross flow heat exchanger.
Forrest_Gump is on a distinguished road
I am supposed to do an analysis of two fluid cross flow plate fin type heat exchanger for my college project.
The heat exchanger is insulated from the surroundings. The heat exchanger is investigated for step perturbations provided in hot fluid inlet temperature. The corresponding response at the outlet of cold fluid is studied.
Can anyone tell me what software should I use for the analysis and post me a tutorial to understand the process?
Thanks
Forrest_Gump is offline   Reply With Quote
Old   April 17, 2016, 06:20
zeshan
Thecomebackkid is on a distinguished road
Originally Posted by Forrest_Gump View Post
Thanks
Hi, i knew someone that studied something similar using Ansys. Never used it myself but should be straightforward and a lot of other ppl use it.
Thecomebackkid is offline   Reply With Quote
Old   December 3, 2017, 11:39
Francisco Angel
francisco.angel is on a distinguished road
Thanks
If you have access to comsol you can search the crossflow heat exchanger tutorial between the case files that are included in the installation, it uses a similar similar geometry, with five cold channels and five hot channels stacked one over the other.
See the image on this link:
https://drive.google.com/open?id=15v...j78wsOILVT9hUB
francisco.angel is offline   Reply With Quote
Old   December 3, 2017, 12:30
Default msh in gmsh
Leonardo
Leoonardo is on a distinguished road
how can I make a duplicate mesh in the structure and not duplicate in the fluid in the GMSH?
Geometry is the cross section of the guitar, I'm having trouble putting just fluid in the sound hole of the guitar.
and I need the mesh to be triangular regular
between point(4) and point (5), it's the sound hole, and there I need it to be just fluid and the line(4) disappears.
help me please, i'm beginner of scientific research
msh code .geo
dim = 34;
gridsize = dim/4;
dim2 = 38.3;
gridsize2 = dim2/4;
dim3 = 48;
gridsize3 = dim3/4;
Point(1) = {0, 0, 0, gridsize};
Point(2) = {dim3 , 0, 0, gridsize3};
Point(3) = {dim3 , 10.5, 0, gridsize3};
Point(4) = {dim2, 10.5, 0, gridsize2};
Point(5) = {dim, 10.5, 0, gridsize};
Point(6) = {0, 10.5, 0, gridsize2};
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 5};
Line(5) = {5, 6};
Line(6) = {6, 1};
Line Loop(1) = {6, 1, 2, 3, 4, 5};
Plane Surface(1) = {1};
Leoonardo is offline   Reply With Quote
heat exchanger, heat exchanger two fluids
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
heat exchanger analysis durgesh pal Main CFD Forum 2 January 29, 2015 05:03
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Simulation of Helical Heat Exchanger in CFX : Fluid Flow Software topper611 CFX 1 March 19, 2013 04:49
