December 4, 2017, 02:36 |
Fluid flow through a domain
Hells Blade
Rep Power: 8 |
I am simulating the flow from these (3 inlets) 8 attached figure untill the top of the plate where my outlet is located.
I am using the following BC Inlet - Pressure Inlet Outlet - Mass flow outlet I am working on inlet pressures between 6- 24 bars . Do i need to use K epsilon or k omega turbulence models currently i am running my simulations in laminar model Due to high pressure of 6-24 bar as enough turbulence is generated do i need to select a turbulence model Also to get accurate results how fine should my mesh or the skewness of the mesh elements be ? |
December 4, 2017, 04:15 |
Uwe Pilz
Rep Power: 15 |
You cannot solve such a problem to a high accuracy using some kind of recipe. The degree of turbulence does not only depend of the pressure, but to a high degree of the viscosity.
At first you need to know what accuracy you need. Do you want so see the flow pattern in principle? Or do you need some values near teh border, perhaps for heat or mass transfer? Quite different. At first I recommend to use a high quality net without a higher degree of skewness. Your case is simpel and that can be reached easily. The experiment with finer and coarser meshes to see how the mesh influences your simulation. At last you may try the difference between RANS and LES. If you are at this point you should have a good feeling of which aspects of your model you may trust in and which are weak points.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
December 4, 2017, 04:22 |
Hells Blade
Rep Power: 8 |
Thanks Mr Uwe I basically need to see the flow pattern and see how my mass flow rate varies when i vary the pressure or the no of inlets
December 5, 2017, 06:59 |
Ravindra Shende
Rep Power: 15 |
There can be no 'mass flow outlet' boundary condition. Which software are you using?
Even if its there, it sounds like you have to specify the mass flow rate at outlet but your objective is to find out the mass flow rate for different inlet pressures. I suggest you use 'pressure outlet' boundary condition and specify a constant pressure at the outlet. Then by varying inlet pressure, for the same outlet pressure, you will get different mass flow rates. You can use any turbulence model if your concern is only about the mass flow rate at the outlet. Finally, as Mr. Uwe suggested, carry out a grid independence study to determine what grid gives you accurate results. |
December 5, 2017, 09:24 |
Hells Blade
Rep Power: 8 |
Ansys fluent but i have a small doubt as there will be a mass outflow the fluid used is air which is highly compressible so in this case density based solver should be used
December 5, 2017, 11:20 |
Ravindra Shende
Rep Power: 15 |
specify total pressure and total temperature at the inlets and static pressure at the outlets
December 5, 2017, 23:53 |
#7 | |
Lane Carasik
Rep Power: 14 |
I highly recommend against using mass flow outlets, it isn't a good combination of boundary conditions. |
December 11, 2017, 05:50 |
Outlet Pressure
Hells Blade
Rep Power: 8 |
I need to check my outlet pressure in pressure outlet how can i enter gauge pressure when the pressure at outlet isnt known
December 11, 2017, 09:51 |
#9 |
Ravindra Shende
Rep Power: 15 |
December 11, 2017, 10:04 |
#10 |
Hells Blade
Rep Power: 8 |
I am using pressure inlet BC you can refer the attached figure my inlet pressure atm is 6 bar which i can vary till 24 bar also change the no of inlets and check my flow vel , pressure and mass flow rate at outlet
December 11, 2017, 11:07 |
#11 | |
Ravindra Shende
Rep Power: 15 |
If you use pressure outlet boundary condition at the outlet then you cannot check the pressure at outlet, because you have enforced it there. In my earlier question what I wanted you to understand is that in your case the flow is happening because there is a pressure difference. I suggest you study your problem in details. |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Can CFX model periodic heat transfer problem | Ethan_Sparkle | CFX | 41 | June 14, 2017 07:22 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
pulsatile blood flow - developing larger pressure in the fluid domain | KushalJ | CFX | 4 | April 29, 2015 00:14 |
