Tesla Semi aerodynamics
Like Tree5Likes
  • 1 Post By wouterremmerie
  • 1 Post By Martin Hegedus
  • 1 Post By FMDenaro
  • 1 Post By arjun
Old   January 5, 2018, 09:03
Default Tesla Semi aerodynamics
Wouter
wouterremmerie is on a distinguished road
Hi all,
I would like to have comments of technical people on an article we've recently launched on the new Tesla Semi:
https://www.airshaper.com/media/tesla_semi.pdf
It is mainly aimed at non-technical people but of course we will get (sceptical?) comments from the technical corner as well.
Therefore, I would like to get warmed up and receive your most uncensored & honest comments possible!
PS:
I'm a technical guy too, so it may hurt me a little, but go ahead
Regards,
Wouter Remmerie
CEO
AirShaper NV
wouter@airshaper.com
+32 486 89 87 86
flotus1 likes this.
wouterremmerie is offline   Reply With Quote
Old   January 5, 2018, 13:30
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
In my opinion there is nothing really surprising... high speed railway trains have now similar aerodynamic shape to reduce drag and their velocity is higher than tracks.
FMDenaro is online now   Reply With Quote
Old   January 5, 2018, 14:42
Martin Hegedus
Martin Hegedus is on a distinguished road
I gather you are making a comparison of the Tesla truck to a European truck and not a U.S. truck. U.S. and European trucks are significantly different for a reason. Not sure exactly why, but I believe it's due to regulation.
My two cents in regards to drag, there is drag due to the forebody, base, undercarriage, and skin friction. I believe a substantial amount of the drag comes from the base. And base, along with undercarriage, drag is challenging to capture. If I were in the audience I would expect to be shown that, at a minimum, one can reasonably capture base drag with the analysis method they are using. By looking at your streamlines I gather you used a RANS method. RANS, in general, does poorly on the base.
Martin Hegedus is offline   Reply With Quote
Old   January 11, 2018, 09:45
Wouter
Hi all,
thanks for the feedback!
Indeed, we use RANS to perform our simulations and it has more difficulties to capture separation then for example LES or Lattice Boltzmann. But for our target audience, designers & engineers that want to rapidly gain insight during the design stage, RANS can still be quite useful (and accurate if mesh is fine enough).
Thanks for the comments, I'm armed better now
Regards, and if there are any questions, just shoot!
Wouter.
Old   January 11, 2018, 11:22
Martin Hegedus
1) For this case, RANS can capture the separation occurring at the sharp edges of the base accurately.
2) The inaccuracy of RANS is a result of the high levels of eddy viscosity that smooths out the unsteady aspects of the wake and thus affects the pressure distribution on the base, or other backward facing surfaces. Refining the grid will not improve that aspect of inaccuracy.
FMDenaro likes this.
Old   January 11, 2018, 11:26
I agree, the magnitude of the turbulence model in RANS exceeds that of the local truncation error you can reduce by a very fine grid.
Martin Hegedus likes this.
Old   January 12, 2018, 03:44
Default Thanks
Wouter
Hi all,
thanks again for the feedback!
We're looking at unsteady sims as well (LES perhaps) for the future.
Although this might sky-rocket computer cost
Does anyone have a (very rough) estimation on how the calculation time would increase from RANS to LES for an identical mesh (I know, this question is full of holes, like the mesh might be different between both, depends on LES settings etc, but still !)
Thanks
Wouter.
Old   January 12, 2018, 03:49
Originally Posted by wouterremmerie View Post
Hi all,
Thanks
Wouter.
As you wrote, the mesh sizes used in LES and in URANS can be quite different. The computational cost for LES increases because you need to go over in your run after that the solution is fully correlated to sample the data to be post-processed.
Then, the cost in LES increases if you adopt the dynamic SGS model.
Old   January 17, 2018, 01:59
Arjun
arjun will become famous soon enough
Hi all,
Thanks
Wouter.
I am working on this exact issue for one company (Can't name). They now do LES with roughly 1.5 billion cells and calculation takes almost like 2 to 3 months to finish due to transient nature. They also calculate drag and lift.
What we are trying is to have third order solver and then reducing the model size by 7 to 10 times while trying keep cost per time step not much more than second order solver.
If this is what is bugging you it would be nice if you kept eyes on Wildkatze3O solver. I intend to make it public in march start.
(currently tests planned on super computing facilities here and until testing is finished it won't be public).
arjun is offline   Reply With Quote
Old   January 17, 2018, 06:15
Wouter
Dear Arjun,
1.5billion cells, that is impressive!
I can't imagine that this is for the automotive industry, so my money is on aviation (I don't expect any reply on this one!).
That solver, is it for OpenFOAM or a standalone solver?
By trading mesh resolution for a higher order scheme, are you worried you loose some of the geometry detail? Or is it already so detailed that it does not matter much anymore?
And is it not quite difficult to get a third order scheme stable?
Very interesting!
Wouter.
Old   January 17, 2018, 09:23
Computing viscous drag in LES requires to solve the BL and the grid reaches easily the order of 10^9 nodes. High order schemes do not change the final resolution dictated by the grid size but acts to gives to the SGS model a more accurate filtered field. What is the shape of this filtered field is a different issue....
Old   January 17, 2018, 12:54
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
For an identical mesh it is somewhat plausible to make this estimate. From my wall bounded flows experience:
Let's say you have been using whatever software to do steady RANS (on a really fine mesh with y+ ~ 1 or less already) and now you naively just switch to transient LES and let it run. It is quite comparable to switching from RANS to URANS (but of course with super tiny time-steps for your LES).
I would generally estimate it as 1 order of magnitude from switch from RANS to transient. And the number of time-steps is on the order of 100k-1million. So that I would say the LES is roughly 100x more expensive than RANS. That number is subjective because it depends on your typical RANS, do you normally achieve convergence within 1000, 10000, or 100000 iterations? i.e do you consider convergence as residuals of 1e-03,1e-06, etc. So maybe 1000x?
LuckyTran is online now   Reply With Quote
Old   January 17, 2018, 23:58
Arjun
Dear Arjun,
Very interesting!
Wouter.
This company is a sports equipment company.
We are still in process of validating and seeing if we really gaining on efficiency or not. It will take some time to make valid conclusions.
What is for sure though is that for the same mesh you do get more accurate results. So even for finer meshes using higher order is not bad idea.
The solver is something I wrote (so far I am only one person developing it). Here is a preview of current version.
https://youtu.be/v8yLx8AvRYw
Note that this GUI is not yet available to public as this java based gui is just been developed. Current public version has Qt based GUI so that does not show next iteration of this solver.
Old   January 18, 2018, 00:01
Arjun
There are lots of interesting things came out of this exercise. So far the cost increase in third order solver is roughly 60 to 70 percent per iteration. What it means is that if early it took 10 seconds then for same mesh now it would be 16 to 17 seconds. But accuracy increase is much higher.
So one of the major things that I amm thinking is that even for same mesh size it would make sense to do higher order CFD just for accuracy purposes and this could be viable alternative to second order solver.
Old   January 18, 2018, 03:22
Wouter
Hi Arjun,
that looks impressive, your solver!
Nice work.
Thanks for all the input, it is very helpful.
It counters a bit the feedback I often get to stick to first order schemes for stability reasons (which is still a valid remark I think, but I did not realise the moderate penalty on iteration time for switching to higher order schemes).
Good luck with the software!!
Old   January 18, 2018, 03:40
The issue is quite more complex... In LES, the accuracy order must be associated to the shape of the filter one expects in the simulation (I mean about implicit filtering). If you are using FV method, you can increase the flux reconstruction to higher order but the resolved (filtered) field is still second order in space compared to the "ideal" DNS field, according to the meaning of the top-hat filter. Conversely, if you use FD, the higher order discretization of the derivatives affects directly the implicit filtering. Theoretically, the more the accuracy of FD the more the filter tends towards a spectral resolution.
Therefore, the choice of the accuracy is somehow a parameter in the "project" of the filter one want to be in effect. And that affects the characteristic filter width one has to prescribe in the SGS model.
Old   January 18, 2018, 23:12
Arjun
Hi Arjun,
Nice work.
Thats the challenge part that the solver shall be stable for industrial applications while maintaining accuracy. It is not easy but we try.
Old   January 18, 2018, 23:14
Arjun
Also facing another issue of viscous term that hardly provide better than second order.
Over all it has been tough business with third order solver.
Old   January 19, 2018, 03:16
This issue could be relevanto for the dynamic eddy viscosity model. However, in this case the test-filtering will be a further operation where accuracy can be relevant... they appears as nested problems...
arjun likes this.
Trackbacks are On
PhD in aerodynamics t.teschner Lounge 6 June 13, 2013 05:55
NVIDIA Tesla GPU ztdep Hardware 0 December 7, 2010 21:00
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen CFX 4 February 27, 2007 21:12
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen Main CFD Forum 7 February 27, 2007 16:54
Consultant w/ Expertise in Aerodynamics & CFD Philip Sorensen FLUENT 0 February 19, 2007 13:45
