What velocity value to use for time step size? |
February 7, 2018, 15:08 |
Violet
Rep Power: 9 |
Hi CFD earthlings,
I understand that when calculating the time step size, you take into account the delta x( of the smallest mesh cell) and the velocity. But what velocity value do I use? The maximum velocity? Free stream velocity? My geometry resembles a cylinder with pipes. However, the inlet surface area is much bigger than the area in the small pipes. Which maximum velocity do I take into account? The one at the inlet surface or once the velocity has been developed in the narrower pipes? Thank you. |
February 7, 2018, 16:43 |
Lucky
Rep Power: 65 |
You take the velocity of the same cell, the "smallest mesh cell" one. Use your best judgment to guess what that velocity will be. Note that it doesn't have to be the smallest mesh cell, but guessing from the global maximum velocity and global minimum cell size are both good places to start.
February 7, 2018, 21:59 |
February 8, 2018, 03:35 |
Filippo Maria Denaro
Rep Power: 71 |
The correct stability analysis considers the most critical value of the ratio between the grid size and the velocity. OF course for homogeneous grid size one considers only the most critical velocity.
Be careful that in multidimensional case the constraint of the CFL extends to the sum of each term |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, | cfdproject | OpenFOAM Meshing & Mesh Conversion | 0 | April 14, 2009 15:45 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
