Hong M.H |
February 22, 2018 05:51 |
Mixing between two fluids (species transport)
Hi guys, currently i m working on simulation regarding the mixing between fluid A and B from two different inlets...i m using species transport model...i know that the bulk species has to be at the last in the mixture template...My bulk species is fluid A.
Fluid A = pure water (inlet 1)
Fluid B = water with dye (inlet 2)
I have set the mass fraction of dye in inlet 1 as 0 whereas the mass fraction of dye in inlet 2 as 0.2...
Afterwards, when i output the mass fraction of dye in particular plane (located at further downstream of the mixing channel), the mass fraction of dye becomes nearly zero (10^-15)...i have expected that mass fraction will reduce but not equal to 0...is it i miss out something in the settings or this is normal results for species transport?
Even though i exchange the bulk species, the result still the same, the mass fraction of the water becomes nearly zero...
i really need some help in this case...
