Fully Developed Two Phase Oil-Water Velocity Distribution |
February 25, 2018, 20:21 |
Fully Developed Two Phase Oil-Water Velocity Distribution [Solved]
Shafik Walakaka
Rep Power: 8 |
Hi everyone,
I am currently modelling a two-phase flow through a pipe. I was wondering if the fully developed velocity would be constant (steady-state)? Kind regards Shafik Last edited by walakaka; February 28, 2018 at 14:04. |
February 26, 2018, 01:55 |
Buddy that's the definition of fully developed flow right. After entry length, the velocity profile should not change, then it is a fully developed flow, Right !! I am not sure but I don't think number of phases would matter in velocity profile. In fully developed flow you will have same velocity downstream from definite distance from wall. Even for steady state, we extrude the inlet so that we get the fully developed profile at actual inlet and not forced BC's (constant velocity across c/s of inlet). Hope you understand what I mean here.
February 26, 2018, 17:13 |
#3 | |
Shafik Walakaka
Rep Power: 8 |
I'm simulating oil-water stratified smooth for now Regards Shafik |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 05:43 |
Specify velocity distribution for droplets | HuifengGong | CONVERGE | 1 | December 22, 2016 14:59 |
Patch fully developed velocity and turbulence profile over full domain | Teumde | FLUENT | 2 | June 29, 2015 13:47 |
[Very urgent] How to write a C Source File For 3D fully developed | evolutionf33 | Fluent UDF and Scheme Programming | 0 | February 25, 2012 05:16 |
Fully developed flow ,CEL expression | kmgraju | CFX | 0 | August 6, 2010 04:15 |
