Simulation heat transfer Pinfin cooling Fluent |
April 13, 2021, 10:43 |
Mercurial
Rep Power: 5 |
Hi guys,
I'm trying to find the experimental document for simulating the heat transfer of pin-fin cooling in turbine blade. I have read many but I can't find any document about pinfin have Heat flux on the wall. Anyone have done with the simulation heat transfer of Pin-Fin cooling ? Please help me to understand and suggest me some document about Pinfin cooling. Thanks all. |
April 13, 2021, 10:56 |
#2 | |
Kira
Rep Power: 8 |
There are plenty of YouTube videos on this topic, such as: https://www.youtube.com/watch?v=RasNjxVy6mY |
April 13, 2021, 11:11 |
Rep Power: 16 |
your question is a bit too vague to be able to help you. Pin fin cooling is a very broad topic and has been investigated in numerous studies. For gas turbine cooling, you might search for some older (but very good) papers by Metzger et al. for experimental reference data and correlations. For CFD, it depends a lot on how you want to proceed: is it going to be fluid only or are you planning to run a CHT simulation... That will affect your choice of boundary condition. Both fixed wall temperature or wall heat flux are physically valid, it depends on the scenario that you want to simulate. |
April 13, 2021, 11:15 |
#4 | |
Mercurial
Rep Power: 5 |
April 13, 2021, 11:25 |
#5 | |
Mercurial
Rep Power: 5 |
This is a example https://citeseerx.ist.psu.edu/viewdo...=rep1&type=pdf I have a simulation document of the another use above document. But when i read, i can't find any information about heat flux, they just indice that the heat wall is constant heat flux, no quatity of heat flux, velocity 3.15+temperature 287K inlet, pressure outlet 0 and other wall is adiabatic. |
April 13, 2021, 11:26 |
Kira
Rep Power: 8 |
April 13, 2021, 11:32 |
Mercurial
Rep Power: 5 |
April 13, 2021, 11:41 |
#8 | |
Kira
Rep Power: 8 |
Velocity, geometry, material and temperature are really all you need. Also sorry about earlier, I should stop assuming all users here are engineers/senior engineering students. |
April 13, 2021, 11:54 |
#9 | |
Mercurial
Rep Power: 5 |
April 13, 2021, 12:21 |
#10 |
Kira
Rep Power: 8 |
No worries. I have taken heat transfer already and it was one of my favourite courses. Best of luck, do let us know if you have any questions regarding the material.
April 13, 2021, 12:29 |
#11 |
Mercurial
Rep Power: 5 |
All example in this material have enough variable to calculate with Q=k(Tw-Tb) and not concern with Nusselt number. In fluent, boundary just have heat flux or temperature on wall. Do u have any document regarding Nusselt number and calculate Heat Transfer in CFD?
April 13, 2021, 14:15 |
#12 | |
Kira
Rep Power: 8 |
Here is a thread that goes over how to do it in Fluent: Nusselt number calculation in Fluent |
Question about heat transfer simulation convergence | Anna Tian | CFX | 27 | January 13, 2021 14:43 |
Simulation of Heat Transfer in Tubes in Fluent Software | wazard | FLUENT | 1 | January 2, 2018 17:23 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Heat transfer simulation in electric motor by using fluent | thuanckdlvn | FLUENT | 1 | March 20, 2013 06:32 |
