Debugging fortran loop
Old   April 9, 2018, 04:41
Default Debugging fortran loop
ulfa
ulfaazmi is on a distinguished road
Dear everyone, I made a codes of Fortran for initial condition of CFD problem, for Velocity (U,V), Pressure (P), and Temperature (T) in one subroutine, but in that case, I want to display that values on the screen only for testing, but I got the problem, only the value of temperature that can appear on the screen. Meanwhile, when I save the data into a file, it is success. Anybody can help me??
this is my code:
!###########################INITIAL CONDITION#####################
PROGRAM CINITI
implicit double precision (A-H)
implicit double precision (O-Z)
PARAMETER(NX0=20, NY0=20)
COMMON/D1/NX,NY,NXU,NYV
COMMON/D2/DX,DY,DT
COMMON/D3/VIS,ALP,BUO
COMMON/D4/RE,PR,GR,TIME,OMG,EPSP
COMMON/D5/ICYCLE,ITR,IFLG
COMMON/D6/DMAX
COMMON/D7/ITYPE,ICOORD
COMMON/ARRAY1/U0(0:NX0, 0:NY0+1),UN(0:NX0,0:NY0+1 ),&
V0(0:NX0+1,0:NY0 ),VN(0:NX0+1,0:NY0 ),&
P0(0:NX0+1,0:NY0+1),PN(0:NX0+1,0:NY0+1),&
T0(0:NX0+1,0:NY0+1),TN(0:NX0+1,0:NY0+1)
NX = NX0
NXU = NX0
NY = NY0
NYV = NY0
!#############START FOR TIME=0 (ICYCLE=0)
!_____________SET U_______________
WRITE(*,*)'UX(I)='
DO 10 IXU=0,NXU
DO 20 IY=0,NY+1
UN(IXU,IY) = 0.0D0
WRITE(*,*) UN(IXU,IY)
20 CONTINUE
10 CONTINUE
!_____________SET V_______________
WRITE(*,*)'VY(I)='
DO 30 IYV=0,NYV
DO 40 IX=0,NX+1
VN(IX,IYV) = 0.0D0
WRITE(*,*)VN(IX,IYV)
40 CONTINUE
30 CONTINUE
!_____________SET P________________
WRITE(*,*)'P(Z)='
DO 50 IY=0,NY+1
DO 60 IX=0,NX+1
P0(IX,IY)=0.0D0
WRITE(*,*)P0(IX,IY)
60 CONTINUE
50 CONTINUE
!_____________SET T________________
print*,'T(Z)='
DO 61 IY=0,NY+1
DO 62 IX=0,NX+1
TN(IX,IY)=0.0D0
WRITE(*,*)TN(IX,IY)
62 CONTINUE
61 CONTINUE
!_________RIGHT SIDE______________
DO 70 IY=0,NY+1
TN(NX+1,IY)=2.0D0*(-0.5D0)-TN(NX,IY)
70 CONTINUE
!_________LEFT SIDE_______________
DO 80 IY=0,NY+1
TN(0,IY)=2.0D0*(+0.5D0)-TN(NX,IY)
80 CONTINUE
!___________UPPER_________________
DO 90 IX=1,NX
TN(IX,NY+1)=TN(IX,NY)
90 CONTINUE
!___________LOWER_________________
DO 95 IX=1,NX
TN(IX,0)=TN(IX,1)
95 CONTINUE
END CINITI
Thank you very much.
ulfaazmi is offline   Reply With Quote
fortran code, loop
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
