June 14, 2018, 07:21 |
Convective terms schemes
Khaled Ahmad
Rep Power: 10 |
What is the most common differencing scheme used for convective terms recently?
The cases are sudden expansion and a flow over cylinder. The flow is incompressible. Using FV method and RANS The grid is non-orthogonal non-staggered structured |
June 14, 2018, 07:56 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Considering only incompressible flows, I can suggest using FV formulation to fulfill conservation of mass and momentum. Often the type and order of the discretization depends on what formulation you use (RANS/LES/DNS). You should provide more details about your interest |
June 14, 2018, 08:07 |
#3 | |
Khaled Ahmad
Rep Power: 10 |
I am using FV with RANS formulation and the flow is incompressible. |
June 14, 2018, 08:09 |
Rep Power: 71 |
June 14, 2018, 08:17 |
Khaled Ahmad
Rep Power: 10 |
I see. I was intending to use the Upwind scheme.
I was afraid that this will affect the accuracy. But can you please state the reasons that no need to use higher order schemes for such conditions? Thanks |
June 14, 2018, 08:22 |
#6 | |
Rep Power: 71 |
The contribution given by the RANS model has greater magnitude order than the local truncation error of the discretization. You will not get advantage in using high order schemes |
Fundamental questions about numerical schemes | Obad | OpenFOAM Running, Solving & CFD | 1 | May 10, 2021 10:40 |
Influence of schemes on mesh size, orientation and type in a convective flow field | Tobi | OpenFOAM Verification & Validation | 8 | July 16, 2017 08:01 |
non-orthogonal corrections for convective terms | Jonathan | Main CFD Forum | 2 | June 12, 2013 12:55 |
Convective schemes for vector fields | edoardo | OpenFOAM Running, Solving & CFD | 6 | February 16, 2009 11:05 |
Implicit or explicit treatment of convective terms | CH | Main CFD Forum | 1 | March 14, 2007 07:51 |
