How to model a long slit type spray cooling arrangement?
Old   July 10, 2018, 02:46
Default How to model a long slit type spray cooling arrangement?
Sagar
Dave110 is on a distinguished road
Dear All,
I want to setup a case for CFD simulation of flat plate spray cooling arrangement. In my experimental setup, there is one long slit type sprayer and it is a spray of gravity driven water and high pressure air.
I have the flow rate of water and air at the inlet as well as pressure of blower. I am attaching an image which shows the arrangement of slit and moving plate.
I try to model it with DPM flat fan atomizer model. But I am not clear about what type of atomizer I should use? Apart from inlet flow rates, pressure and velocity of plate what are the other input parameters I have to decide to setup DPM model?
Dave110 is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Problem with continuity simpleFoam kkl omega airfoils ibelunatic OpenFOAM Running, Solving & CFD 0 March 20, 2018 11:48
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
multiphaseEulerFoam/tank discharge ves OpenFOAM Running, Solving & CFD 8 December 31, 2017 14:59
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
