July 16, 2018, 05:49 |
Loading an STL file to paraview
Hillary Kiptoo
Rep Power: 7 |
Hello Foamers.
I have a problem though, I am getting an error while trying to load an stl file into paraview. Here is the error. ERROR: In /home/openfoam/OpenFOAM/ParaView-5.0.1/VTK/IO/Geometry/vtkSTLReader.cxx, line 461 vtkSTLReader (0x62f35a0): STLReader: error while reading file /home/larry/Desktop/owc.stl at line 3: unable to read point. ERROR: In /home/openfoam/OpenFOAM/ParaView-5.0.1/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkPVCompositeDataPipeline (0x63e52c0): Algorithm vtkFileSeriesReader(0x63e3b50) returned failure for request: vtkInformation (0x58a3e60) Debug: Off Modified Time: 331199 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 Your help in how to go about this problem will greatly be appreciated. |
August 22, 2018, 10:37 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings larry k,
I only now managed to take a look into your question. I hope you've solved the problem by now, but if not, it would be necessary to open the STL file with a text editor and take a look inside it to understand why it's not working. The page for it at Wikipedia: https://en.wikipedia.org/wiki/STL_(file_format) - has a fairly detailed explanation on what to expect inside the file. If you haven't solved this issue since then and if you still need help, then please share the first 5-10 lines of the STL ascii file, unless it's in binary format. Best regards, Bruno
August 22, 2018, 19:09 |
Loading STL file in Paraview
Hillary Kiptoo
Rep Power: 7 |
Hello Bruno,
Thanks for your response. I got a solution to it, apparently my geometry was not a closed surface but I sorted it out. Kind regards. |
paraview 4.1 |
Display Modes | |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 19:13 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
