April 14, 2000, 11:00 |
Contour plotting
Hi, I have written a piece of code to solve some simple heat transfer problems and to display the output also have written a simple contour plotting routine. The output could be better but because of the simplicity of my code I don't want to spend all my efforts developing the post-processing component.
Does anybody out there have, or know of, a 'free' contour plotting routine that I can drop into my program. For reference my 'parent code' has been developed in an early version of MS Visual C++ and runs under MS Windows. Thanks in advance. |
April 16, 2000, 12:43 |
Re: Contour plotting
(1). Try the commercial post-processor programs or the vendors. (2). The graphic program is much harder to write and it is usually much longer than the solver part.
April 17, 2000, 03:17 |
Hello, Try Mathematica it can do it.
April 18, 2000, 17:23 |
Hi .. I suggest you to spend more time and improve ur code... It will be good exercise for you...I will give a hint: "It is matter of interpolation to have the iso-lines".. If u gave up just contact me i have it in visual basic.. Hope you good luck
April 21, 2000, 09:51 |
Try to use Surfer or Origin.
April 22, 2000, 22:45 |
Try Matlab 5.3. It is a great package for plotting contours. As a matter of fact you can automate the whole process by generating the corresponding C++ code by using the Matlab Graphics Compiler and embedding the resulting code in your application.
Display Modes | |
Reynolds contour plotting in cfx-post | mortazavi | CFX | 3 | June 3, 2009 07:34 |
Vof contour plotting | Shane | FLUENT | 1 | October 8, 2006 04:57 |
CONTOUR PLOTTING | Dr M.A. Waheed | Main CFD Forum | 1 | November 2, 2005 04:24 |
Contour plotting with origin or matlab | M. A. Waheed | Main CFD Forum | 0 | November 1, 2005 02:42 |
Tecplot problem of plotting boundary in contour | mafoi | Tecplot | 1 | April 5, 2005 06:43 |
