Precleaning in Air cleaners
Old   April 21, 2000, 09:46
Default Precleaning in Air cleaners
Prasad Padwal
Dear sir, I would like to know how actualy the precleaning of dust takes place in a tangential type of air cleaner.Also what are the factors affecting the precleaning efficiency of an air cleaner.
Thanks,
Prasad
Old   April 22, 2000, 22:51
Default Re: Precleaning in Air cleaners
John C. Chien
(1). Which part of the question is related to CFD? (2). Can you talk to the manufactures of these "air cleaner"?
Old   April 25, 2000, 13:37
Alton Reich, PE
Prasad,
I'm also not sure what this has to do with CFD, and I'm also not precisely sure what you're after, but I'll take a shot.
Good old-fashioned filers like the blue fiberglass mesh ones I used to use in my air conditioning system at home work by trapping air-borne particles. The particle laden air flows through the filter's fibers. As the air flows, the particles may get trapped at the intersection where fibers cross, or the particles may impact a fiber and stick to it. These filters are very inexpensive (less than $1 each at the local Home Depot), but they are not very good at air cleaning. The gaps between the fibers let small particulates like pollen pass right through.
I now use pleated filters that have much smaller gaps between the fibers. These filters are also electrostaticly charged to attract things like dust and pollen. It makes it much more likely that the small particulates will impact the fibers if they are attracted to each other.
I hope this helps, Alton
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Simulation of air flow in a chamber Issa CFX 3 November 23, 2009 17:16
Chemical Equilibrium Composition of Air and other Species enigma Main CFD Forum 0 November 11, 2009 19:08
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 07:04
