[Sponsors] | |||||
Abbas Raza
Rep Power: 9 ![]() |
I am new to CFD. A cube sitting at the bottom of the wind tunnel. What boundary conditions do I apply and what are the general steps I need to take to run an analysis?
Lee Strobel
Rep Power: 11 ![]() |
First question is what CFD software package are you using? To be honest, it sounds like you could really do with going through a basic tutorial or training course for that package. Perhaps it has online tutorials that you can do?
Abbas Raza
I'm trying to understand CFD for academic purpose.
Lee Strobel
@raza22: your question is very broad, so I will only be able to give a very general answer:
For a cube in a wind tunnel, you would need to apply non-slip wall boundary conditions to the walls of the tunnel and cube, as well as flow inlet/outlet b/cs at the inlet and exit of the tunnel. In terms of the general steps to run the analysis, it would just follow the same basic steps as any CFD analysis: 1. Construct the model geometry 2. Mesh the flow passage 3. Apply material and physical models (e.g. turbulence, energy) 4. Apply boundary conditions 5. Select and set up the solver (plus any monitors) 6. Initialize the flow field 7. Run the solver, until a desired level of convergence is achieved 8. Post-process and interpret the results |
Abbas Raza
What advantages do CFD simulations have over the wind tunnel
experiments? |
#6 | |
Filippo Maria Denaro
Rep Power: 75 ![]() ![]() ![]() |
This question can be totally reverted in: what is the advantage of a wind tunnel experiment over CFD? I strongly suggest to understand first that CFD is a field that starts from physics and mathematics. You have to understand your physical model, what mathematical PDE and BC.s can be used to model correctly the problem, what discretization can be suitable and then what is the solver to use. If you have to compare CFD and experimental measures you have to understand what kind of measure are available. In your case the flow over a bluff body is a very generic problem. Is the flow assumed compressible or incompressible? Are you considering a Reynolds number that ensure laminar regime or you are facing transitional and turbulent conditions? Are you correctly modelling the wind tunnel geometry in your grid? Last edited by FMDenaro; July 27, 2018 at 14:01. |
Abbas Raza
This answer helped me more than anything. Thank you
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| CFD Analysis Over Three Dimensional CD Nozzle | vickyroczzz | Main CFD Forum | 0 | March 25, 2018 03:19 |
| Vortex Shedding - CFD Analysis Questions | ricod-stareng | Main CFD Forum | 3 | January 28, 2018 14:02 |
| Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
| Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
| Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
