Problem in CFD simulation
Old   August 26, 2018, 13:36
Default Problem in CFD simulation
Ankur Bhatnagar
ankur bhatangar is on a distinguished road
Hey everyone, I am trying to simulate flow over radome using Ansys fluent at Mach 4. Flow domain consist of radome with missile some portion attached to it.. Computational domain consist of cylindrical wall all around as farfield and inlet as farfield and pressure outlet...basically the missile part is fixed to the pressure outlet as shown in figure... The grid consist of unstructured mesh all around with prism layer over radome and missile portion... Everytime I am starting the simulation it's getting unstable and showing #NAN's ... Same mesh is working at low Mach number value 2.5. I am using density based solver with SA turbulence model ..Can anyone explain me what is the problem with simulation ? How can i use the same grid for all Mach number regimes provided range from subsonic to high supersonic..??..
Thanks..
ankur bhatangar is offline   Reply With Quote
CFD simulation of gas cicrcuit breaker in fluent with dynamic meshing. Mahesh7238 FLUENT 1 April 5, 2021 01:21
Specifying BC for LES simulation of pollutant dispersion problem in environment jzuzul OpenFOAM Running, Solving & CFD 8 June 21, 2018 08:21
mpi run problem signal 11 (segmentation fault) FGM simulation Fedindras CONVERGE 1 October 26, 2017 17:05
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 13:26
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 13, 1999 00:27
