September 18, 2018, 06:21 |
#21 |
Rep Power: 17 |
Yes that sounds like two good approaches.
How about the method I presented above, any thoughts about the validity? (I do not consider a method wrong just because there are other methods that may be more fundamental and/or easier to apply. If the math is incorrect then I agree it is wrong though.)
"Trying is the first step to failure." - Homer Simpson |
September 18, 2018, 06:24 |
#22 | |
Filippo Maria Denaro
Rep Power: 71 |
Sorry, I haven't read all the details of what you proposed. I agree that you can get the final result in different ways. For example, starting from the integral form you can get the limit for the measure of the volume going to zero (of course after dividing by the measure of the volume) |
September 18, 2018, 12:54 |
#23 | ||
Lucky
Rep Power: 65 |
Proving that phi(r+delta_r) converges to phi(r) requires more work and more assumptions (i.e. continuous & differentiable). You cannot say any longer than phi can be any flux which contradicts your initial assumption that phi can be any flux. I hope you realize the lack of mathematical/logical rigor in this attempt. Furthermore, simply being differentiable does not yet prove that phi(r+dr) converges to phi(r) in the limit of dr=>0 (which is why you need the taylor approximations, or something else). This is more non-trivial than it seems. the limit of x+dx as dx=>0 converges to x because you know you are dealing with x. You can do an epsilon delta proof using f(x) = x to prove this. But, you have no idea what phi is! It looks trivial because you've seen the solution before you've seen the method to arrive at the solution. |
September 18, 2018, 14:42 |
#24 | ||
Rep Power: 17 |
Thank you for an interesting discussion.
Still not sure what you mean. I have just shown you that there are two methods that can be used to arrive at the differential expression for the equations. One based on Taylor series approximation and the other based on the definition of the derivative (in which part is to take the limit as the sizes go towards zero). I don't think I have said anything about the end result other than that both methods produce the same expression. Then I have tried to prove that. Are you giving my examples as counter-examples to my examples? Quote:
I don't think it is more non-trivial than it seems. phi(r) is just as "unknown" as phi(r+dr). Consider the Taylor series example. You can approximate the flux value at phi(r+dr) using the gradient of phi(r). You can just as easily approximate the flux value at phi(r) using the gradient of phi(r+dr) (a backwards difference in numerical terms). Then you end up with an expression in which phi(r+dr) is given, plus an additional term. However this is fixed by taking the limit as dr-->0. Also, arguments of continuous and differentiable should also apply to the Taylor series expansion, right? The integral form is another matter.
September 21, 2018, 11:39 |
#25 | |
Lucky
Rep Power: 65 |
You need to assume it is differentiable in order to apply Taylor series expansions, yes. But what you are trying to show is how to derive N-S without taylor series. I'm trying to show you the roadblock you are having because you are not using the taylor series. When you say the flux at phi(r+dr) can be approximated using the gradient of phi(r) you are already using taylor approximations in the back of your head. Can it be approximated that? Under what conditions? Prove it! I'm not saying you are not capable of doing such a proof. But in a derivation of any equation, theses are important. Assuming that the flux of phi at r+dr can be approximated means that you will in the end have derived an approximate navier-stokes equations. What you want to derive is much more than that. A 90% derivation is not a complete derivation. |
September 24, 2018, 06:04 |
#26 | ||||
Rep Power: 17 |
I think you can agree that a Taylor series expansion across a shockwave will not work either.. Quote:
Thank you I appreciate that. The best thing would be for you to provide a counter-example where limits do not work, but a Taylor series does work. Quote:
Yes, I wrote "Consider the Taylor series example. You can approximate the flux value at phi(r+dr) using the gradient of phi(r)". Obviously I think about the Taylor series expansion in my Taylor series example. Did you have any other comments on the example? Quote:
I don't understand your point here. Do you mean that I arrive at an approximate solution that just happens to be the same solution as the Taylor series expansion yields? Furthermore, is it your view that the Taylor series expansion derivation is exact?
September 24, 2018, 07:25 |
#27 |
Rep Power: 71 |
I am not sure to follow the meaning of the discussion, the Taylor serie is based on the existance of the derivatives and to guarantee that you have the the limits, whatever directions are, must converge to the same value.
Therefore, using the Taylor serie is the same as invoking the regularity of the function and its derivatives. Again, the derivation of any physical conservation equation must start from the global balance in a volume of small but finite lenght (just think about the fundamental trasnport Reynolds theorem). Only if suitable regularity hypotesis are assumed the equations can be written in differential poitwise form. |
September 24, 2018, 17:04 |
#28 | ||
Lucky
Rep Power: 65 |
From this I got the impression you were trying to prove you derive the n-s equations without using taylor series. You gave an example in cartesian where you were successful. Then you gave an example in cylindrical coordinates where you were not succesful (because you did not use Taylor series). Quote:
If you assume that the flux on the right can be approximated by the gradient, then you derive a pde which is based on this assumption, and it's only an approximation (i.e. it is only 99% accurate). You need to show that the flux can always be written exactly... You missed that Taylor series can be exact under the same conditions that you called approximations. If you stop at the first derivative then you end up with an approximation... which is why you must write down the infinite taylor series with infinite higher order derivatives. |
September 24, 2018, 17:15 |
#29 |
Rep Power: 71 |
Maybe, consider just a my idea, the confusion is on the exact relation
f(r+dr) - f(r) = Int [r; r+dr] (df/dr) dr |
September 25, 2018, 03:36 |
#30 | ||
Rep Power: 17 |
Correct. I gave two examples using limits where I arrived at the same result as a Taylor series approach would give. I have asked you to give a counter-example where this method does not work, but you have not provided one. You just state that the approximation used in my method is wrong. If a counter-example does not exist and I always arrive at the same equation regardless of method then I conclude that both methods are valid. Quote:
1. I think you confuse "i.e." with "e.g." 2. Accuracy only comes into play when you have a finite step-size. 3. "The Taylor expansion method" of deriving the flux equations always assume that the higher order terms can be truncated. This is OK due to point 2 above. 4. Later, the numerical method of solving the differential equation can use higher order difference approximations. This is for accuracy.
September 28, 2018, 09:49 |
#31 | |
Lucky
Rep Power: 65 |
Your cylindrical one did not work. I'm saying your cylindrical example is a counter-example and I don't need to provide another one. You proved you could not do it. One counter-example is sufficient for a disproof. There is a glaring hole in your example which I tried to explain to you repeatedly. You can consider an integral approach like Filippo suggested or something else but you need to use more tools to complete the derivation of the pde. Is that not what this discussion is about? The navier-stokes equations is a pde (the equation is continuous and exact). You write it with an equal symbol (=, always equal) and not an approximately equal (not ~ or the double ~~) symbol. If you say I can approximate the flux at r+dr using blah blah blah then you end up with a pde that is stuff ~ stuff and not stuff = stuff like you should have. Put in the work, prove that you can actually write down exactly the flux at r+dr and you can turn the ~ into a =. |
October 1, 2018, 12:09 |
#32 | |
Rep Power: 17 |
As "proof" I would like to use the derivation presented by Bird, Stewart, Lightfoot "Transport Phenomena, 2nd edition" You can find the derivation using limits for cylindrical coordinates under §2.3 The book is one of the most referenced books when it comes to transport phenomena.
October 5, 2018, 16:27 |
#33 |
Lucky
Rep Power: 65 |
We all know what navier-stokes looks like in cylindrical coordinates. It is freely available on wikipedia and can be seen by anyone at any time. I'm not saying that the equation there or in any particular text is wrong. I'm saying you personally did not prove this limit converges to the limit that you wanted because you missed the conditions needed / you skipped some steps.
The only reason I bring up this point was because you questioned from a pedagogical perspective why some steps were necessary. |
October 7, 2018, 06:59 |
#34 | ||||
Rep Power: 17 |
Yes we all know the equations are available, but that was not the discussion here. Quote:
So this is what you must mean: Quote:
My argument here is that there are two methods of deriving the flux equations in differential form. One is based on Taylor expansion (common in text books on CFD) and the other is based on limits (as presented by Bird, Stewart, Lightfoot). In essence they are the same thing, but for students new to the subject it can be confusing to mix them. In the text provided by Prof. Denaro it seems that both methods are used without explanation. My explanation between the steps would be that when dividing by volume and taking the limits as the control volume shrinks to zero yields an approximation that truncates the Taylor series at the second derivative (i.e. write out at least the second derivative in the Taylor expansion and then keep it until the limit is taken). Quote:
The assumptions are the same as in the Taylor series approach. We end up with the same differential expression. To end the discussion about the phi(r+dr) term being equal to phi(r), would you accept that this approximation is of the same order as the approximation used for the first derivative? You can easily see this from a Taylor series expansion.
Finite Volume Method For Cylindrical Coordinates | falopsy | Main CFD Forum | 45 | August 14, 2023 21:14 |
Fluent calculating cylindrical coordinates | Falldox | FLUENT | 1 | January 31, 2017 10:10 |
SIMPLE algorithm in 3D cylindrical coordinates | zouchu | Main CFD Forum | 1 | January 20, 2014 17:02 |
Cylindrical coordinates ? | T.D. | OpenFOAM Running, Solving & CFD | 17 | September 26, 2010 15:37 |
Calculation in cylindrical coordinates | Franz Wingelhofer | CFX | 0 | December 28, 1999 07:46 |
