Specifying initial conditions with cyclic boundary conditions |
November 13, 2018, 17:59 |
Rep Power: 9 |
I am trying to use a modified transient twoPhaseEulerFoam with cyclic boundary conditions. Now I have to specify the initial volume fractions,velocities,pressures etc at the INLET. How do I do that because I have specified cyclic in the boundary conditions? How do I specify initial non uniform internal field values without using the list option since the mesh is complex? Thanks and regards, Shantanu Vachhani |
November 14, 2018, 12:07 |
Lucky
Rep Power: 65 |
cyclic is the entry for type that you need to specify (for every field). There's still an entry for value that you need to specify (for every field). That's where your initial condition goes.
November 14, 2018, 16:19 |
Rep Power: 9 |
Even after entering a value at the boundary while zero in the uniform field, the simulation doesn't take that into consideration because the alpha(volume fraction) values are zero at every time step. Furthermore , the courant number is very less because I have specified non zero velocity at the inlet while the internal filed is (0 0 0).
Could you think of a reason why is this happening? Thanks and Regards, Shantanu Vachhani Code:
Courant Number mean: 2.29238e-15 max: 3.88904e-15 Max Ur Courant Number = 2.49311e-16 Time = 1.5e-05 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999662, Final residual = 0.999662, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.999985, Final residual = 1.14001e-05, No Iterations 1000 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999683, Final residual = 0.999683, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.999994, Final residual = 1.07173e-05, No Iterations 1000 PIMPLE: iteration 3 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999698, Final residual = 0.999698, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.999992, Final residual = 9.86466e-06, No Iterations 1000 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. GAMG: Solving for psi, Initial residual = 0, Final residual = 0, No Iterations 0 ExecutionTime = 101.63 s Courant Number mean: 1.542e-15 max: 2.61096e-15 Max Ur Courant Number = 1.60923e-16 Time = 2e-05 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999708, Final residual = 0.999708, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.99999, Final residual = 8.67989e-06, No Iterations 1000 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999722, Final residual = 0.999722, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.999996, Final residual = 8.37368e-06, No Iterations 1000 PIMPLE: iteration 3 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999731, Final residual = 0.999731, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.999995, Final residual = 7.84835e-06, No Iterations 1000 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. GAMG: Solving for psi, Initial residual = 0, Final residual = 0, No Iterations 0 ExecutionTime = 134.49 s Courant Number mean: 1.13366e-15 max: 1.91734e-15 Max Ur Courant Number = 1.08311e-16 Time = 2.5e-05 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999737, Final residual = 0.999737, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.999994, Final residual = 7.00422e-06, No Iterations 1000 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999745, Final residual = 0.999745, No Iterations 0 min T.air 300.01 min T.water 300.002 smoothSolver: Solving for p_rgh, Initial residual = 0.999998, Final residual = 6.72276e-06, No Iterations 1000 PIMPLE: iteration 3 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0 Min(alpha.air) = 0 Max(alpha.air) = 0 Constructing momentum equations Selecting patchDistMethod meshWave Selecting patchDistMethod meshWave --> FOAM Warning : From function const volVectorField& Foam::wallDist::n() const in file fvMesh/wallDist/wallDist/wallDist.C at line 200 n requested but 'nRequired' not specified in the wallDist dictionary Recalculating y and n fields. smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 1, No Iterations 0 smoothSolver: Solving for e.water, Initial residual = 0.999752, Final residual = 0.999752, No Iterations 0 min T.air 300.01 min T.water 300.002 |
November 19, 2018, 13:55 |
Lucky
Rep Power: 65 |
I'm still confused what you are trying to do. With cyclic BC, there is no more an inlet.
Your initial condition is specified in value of the internalField and if you ordinary BC's the value of the boundaryField. But you have cyclic and no longer is it necessary to specify value in the boundaryField and only the internalField. Now the question is what you like to specify as the initial condition for the internalField. And yes you must think in terms of internalField. Probably the solution will involve the setFields utility. |
November 26, 2018, 01:00 |
Rep Power: 9 |
LuckyTran,
Thank you for the response. However I have one question about using cyclic boundary condition. When I am using cyclic boundary condition , my internal field specified for volume fraction is 0.5. Now using cyclic boundary condition this value remains same throughout the domain as the simulation progresses. This means there is no mass transfer which is physically incorrect. When I use normal inlet and outlet boundary condition, observable mass transfer is observed. Could you think of the reason why cyclic boundary condition is giving wrong results? Thanks and Regards, Shantanu Vachhani |
boundary condition, cyclic boundary condition, initial condition, internal, non uniform |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 02:13 |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 03:42 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 23:13 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
