November 28, 2018, 06:59 |
Recirculation zone length BFS
Nat K
Rep Power: 8 |
I am performing some LES of BFS flow and I am computing the primary recirculation zone length located behind the step. I am comparing my data with experimental data of Armaly, with difficulty. According to Armaly at Re=2000, the RZL (x/S - length of zone divided by step height) should be roughly 13.5, whereas I am getting quite large value of 20. For greater Re this also increases (linearly) whereas shows decrease. Would anyone know why this would happen? Would wall boundary conditions be the problem? I am using Smagorinsky SGS models, with a mesh of y+ < 1, and no wall functions. Any help would be appreciated |
November 28, 2018, 07:13 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Without more details about your BC.s it is difficult to help you. However, how do you compute the reattachment lenght, after performing a long time averaging? How do you set the inflow profile? The static Smagorinsky model can produce too dissipation, have you tried the dynamic model? Have you checked the statistics ? You can read these articles https://www.researchgate.net/publica...ical_procedure https://www.researchgate.net/publica...mes_simulation |
November 28, 2018, 07:32 |
Nat K
Rep Power: 8 |
Hi Filippo,
Yes I should have put my BCs. I am using OpenFOAM. U: The inflow velocity is a mapped flow condition. Neumann BC on outlet No slip on the walls Cyclic on spanwise faces p: Neumann inlet Dirichlet outlet Neumann walls Cyclic on spanwise faces nut: inlet and outlet - calculated 0 Neuman walls Cyclic on spanwise faces I compute the RZL by time averaging the simulations and looking at wall shear stress along the wall. I have read about Smagorinsky being too dissipative and not predicting transition well, so that may well be the case. I will consider dynamic Smag and see what results I get. |
November 28, 2018, 07:36 |
#4 | |
Rep Power: 71 |
Not only the effect of the Smagorinsky model but also the spanwise extension of the domain (of course the experimental apparatus is confined) and, mainly, the inflow profile affect the results. If you see the papers I linked you could find more explanations. |
November 28, 2018, 11:22 |
Nat K
Rep Power: 8 |
Thanks, will have a read of the papers.
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
how to calculate recirculation length after square cylinder | khalid.elserfy | Main CFD Forum | 1 | August 17, 2015 02:30 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 10:45 |
[GAMBIT] length of recirculation zone | abc | ANSYS Meshing & Geometry | 1 | June 26, 2012 03:12 |
Recirculation length | Tony Chen | Main CFD Forum | 4 | March 4, 1999 12:33 |
