December 8, 2018, 17:08 |
Line implicit
Jake
I was wondering For the three-dimensional incompressible NavierStokes
equations with heat transfer, what is the size of each block in the block tridiagonal matrix that arises from a line-implicit, central difference method? and also For the two-dimensional compressible Euler equations, what is the size of each block in the block tridiagonal matrix that arises from a line-implicit, central difference method? I have done Implicit method for a 1D heat equation before, but right now I'm really puzzled about the mentioned equations and their corresponding block size in the tridiagnal matrix. Thanks alot |
December 8, 2018, 18:19 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
For incompressible flows there are linear systems for the momentum as well as for the pressure equations. What are you considering? What about the accuracy order of the central discretization? For a general second order discretization of the second derivative, you see 7 non zero diagonals that can be organized in block tri-diagonal matrix |
cfd, ine-implicit, tri diagonal matrix |
Unknown function type pressureTools | Dorian1504 | OpenFOAM Post-Processing | 23 | May 25, 2021 09:24 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
