December 13, 2018, 08:12 |
Heat Transfer on fluid-solid interface
Yandong Gu
Rep Power: 9 |
Hello everyone,
I am working on computational codes of heat transfer through a fluid-solid interface. On the interface, is the fluid temperature equal to the solid temperature? or a temperature difference? or depends on flow regime? or others? I am very confused about this issue. Thank you very much for your answer in advance. Last edited by Hubert Gu; December 14, 2018 at 01:09. |
December 13, 2018, 08:19 |
Lucky
Rep Power: 65 |
At interfaces you have an interface condition. I.e. conservation of energy on both sides or whatever. I guess in your example it would be conservation of heat flux. So neither the temperature nor the temperature difference (because thermal conductivity can be different for fluid and solid).
Interface conditions are like boundary conditions and governing equations. They are decided at a very high-level and quite independent of the code itself. |
December 14, 2018, 01:12 |
#3 | |
Yandong Gu
Rep Power: 9 |
indeed, I adopted the equation of heat flux conservation. I am wondering the node of the interface which is shared by the fluid domain and solid domain, that means on the interface the fluid temperature is the same with solid temperature. please see the following picture, am I correct? Thanks again. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Multiphase heat transfer | pkladisios | CFX | 8 | June 7, 2016 01:41 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
