September 27, 2004, 07:46 |
Ringleb flow
Dear Friends,
I am trying to compute the ringleb flow which is purely subsonic . The inlet corresponds to an isovelocity line ( q=0.3)and outlet to the symmetry axis. However, I seem to have some problems with the boundary conditions, specifically at the outlet. The flow is determined by streamlines k=0.5 and k=0.8. With adaptation, the solution is deteriorating. Can you please advise on the bc's for this problem. I have referred to Esser's paper, Coiriers's thesis and AGARD report of Chiocchia. I need the BC s for the problem in details. As of now, the inlet and outlet BC s are Reimann invariants wherein the exact solution is supplied as the missing state. The wall BC s are pressure extrapolation or mirror b.c. . I have experimented by using the Reimann Solver instead of Reimann invariant also at both inlet and outlet, as wellas invariant at the inlet and solver at the outlet. Please advise on the BC s and issues regarding initialistaion, if any. Thanks Ganesh |
September 28, 2004, 11:41 |
Re: Ringleb flow
You may want to look at the boundary condition implementation in the NSC2KE code.
http://pauillac.inria.fr/cdrom/prog/unix/nsc2ke/eng.htm Regards. |
December 28, 2018, 23:11 |
does anyone has solutions or open source code?
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
How to change from mass flow to volume flow rate | stanley | FLUENT | 1 | February 2, 2007 06:44 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
