January 23, 2019, 04:16 |
3D velocity data from 2D data
ssa
Rep Power: 7 |
I have a time series velocity data from wind tunnel in 2d. I have the 'u' component and 'w' component. Is there some way I could calculate the third velocity component 'v' from these data. Thanks, ssa |
January 23, 2019, 04:23 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
No... the continuity equation can address a relation but also assuming you have an incompressible flow, the divergence-free constraint writes dv/dy = -(du/dx+dw/dz) you see that you need to measure directly the data of the third components. |
January 23, 2019, 04:28 |
ssa
Rep Power: 7 |
Hi, Thanks for the quick reply.
One more question. I am in need of calculating reynolds stress tensor for my simulation. so with u and w, I could calculate only three tensor components and I need the remaining three. Is there some way to do it.? |
January 23, 2019, 04:35 |
#4 | |
Rep Power: 71 |
No, unfortunately you do not have a real 2d problem but a 3d flow with only two known velocity components... |
January 24, 2019, 12:30 |
Brandon
Rep Power: 7 |
Someone else will be able to correct me if I am wrong. I have only recently gotten into turbulent flows, etc. But from what I understand, if you consider a flow around an airfoil for instance and if you want to use the experimental data for a simulation, the Reynolds stress terms in the spanwise direction would be zero on account of spanwise homogenity.
If this is what you need, you could probably do it without the third dimension, provided you have data in the right directions. |
January 24, 2019, 13:04 |
Lucky
Rep Power: 65 |
How to read transient velocity profile data as inlet condition at each time step | hemmt | FLUENT | 12 | July 9, 2018 02:26 |
How to read transient data as inlet velocity boundary condition | hemmt | FLUENT | 2 | December 22, 2016 01:30 |
[General] 2 datas on one plot | Akuji | ParaView | 46 | December 1, 2013 14:06 |
Velocity vector data in OpenFOAM and ParaView mismatch | tekky | OpenFOAM | 9 | December 21, 2009 11:26 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
