February 14, 2019, 10:28 |
Reynolds number of a flow around a car
Rafaelle
Rep Power: 7 |
I struggle choosing between the length, the height, and the width of the car to calculate the Reynolds number of a flow around a car. Is the direction of the flow indicates that we should take the length of the car? I tried to find papers on flow around cars and it seems that sometimes the width is used, sometimes the height is used, sometimes the length is used; I'm then a bit confused. Sincerely |
February 14, 2019, 10:35 |
Lucky
Rep Power: 65 |
There are infinite Reynold number variants. There is even a Reynolds number based on font size. What you are going to do with the Reynolds number is what determines which one you use. Why do you need Reynolds number?
Fix Reynolds Number in a periodic flow | chusma | OpenFOAM Pre-Processing | 10 | June 12, 2019 02:08 |
[mesh manipulation] Mesh Refinement | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Meshing & Mesh Conversion | 42 | January 8, 2017 12:55 |
At what Reynolds number, can viscoisty of water be ignored in an open channle flow. | Roule | Main CFD Forum | 13 | September 24, 2015 14:20 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
