rpsetvar,'pressure-correction/relax value
not working rpsetvar,'pressure-correction/relax value 0.4
also tried rpsetvar 'pressure-correction/relax value 0.4 but error comes how to solve it i am using fluent 17.2. thanks |
You have the wrong variable name. Probably you're trying to do one of these.
(pressure-correction/relax-enhance 0.1) (pressure-correction/relax-drdp 1.) (pressure-correction/relax 0.7) if you're trying to set the 0.7 to 0.4 then do rpsetvar 'pressure-correction/relax 0.4 But idk why you're trying to use the low-level rpsetvar command and not one of the high-level TUI commands. |
dear
rpsetvar 'pressure-correction/relax 0.4 invalid rpsetvar error comes, what to do actually by default there is v-cycle in pressure equation, in advanced limit setting i want to lower it as my simulation not converging please suggest me what actually command i put which works corrrectly |
did you type rpsetvar 'pressure-correction/relax 0.4 or (rpsetvar 'pressure-correction/relax 0.4) ?
thanks buddy (rpsetvar 'pressure-correction/relax 0.4)
its work with paranthesis |
