May 15, 2019, 07:45 |
Mass outflow correction
Vignesh Rajendiran
Rep Power: 9 |
Guys,
Can anyone please explain to me about the mass outflow correction (how they work and why we should use them) and the equations involved in them. I am trying to understand them because I have come across some info, that for a compressible simulation one should use pressure outlet BC. I am trying to understand this through the equations. Please shed some light on this. Thanks Vicky |
May 15, 2019, 12:18 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
For compressible flows, the type of inflow/outflow BCs depend on the supersonic/subsonic condition. Fixing a pressure value at the outlet is possible for subsonic conditions. |
May 17, 2019, 04:03 |
Vignesh Rajendiran
Rep Power: 9 |
Then is it right to use the pressure outlet BC for velocity inlet BC for incompressible simulation. Or is the pressure outlet condition limited to only compressible flows.
Thanks |
May 17, 2019, 04:08 |
#4 | |
Rep Power: 71 |
If you solve the fully incompressible model, a Dirichlet BCs. for the pressure can be fixed but it is not necessary, you can work using the velocity BC. However, this model is totally different from the compressible model at low Mach number |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 06:00 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
is there mass outflow or velocity outflow B.C. | kk | FLUENT | 1 | April 12, 2007 10:55 |
Mass flow rate on outflow face | TOM | FLUENT | 1 | February 25, 2002 10:27 |
