-   Main CFD Forum (https://www.cfd-online.com/Forums/main/)
-   -   LES filter- frequency limit (https://www.cfd-online.com/Forums/main/218705-les-filter-frequency-limit.html)
bhigahAshish July 1, 2019 11:15
I have a theorical doubt about the les filter.
The filter, in my software, is the cubic root of the the cell volume.
So if I use, for istance, the grid spacing delta=0,125 m, the resolved frequency should go from 0 to 2*pi/delta, which in this case is almost 50 Hz.
But now I have a doubt, since 2*pi/delta has the unit m^-1 , it should be wavenumber and not frequency.
So I am getting confused. Can you help me to understand which is the frequency limit of the resolved area.
Thank you in advance
FMDenaro July 1, 2019 13:49
Originally Posted by bhigahAshish (Post 737672)
You have an implicit filter, I suppose...You are doing confusion between the filter width (which is a lenght) and the cut-off wavenumber.
That is the filter is implicitly due to the grid and to the numerical scheme. In such s case, the cut-off frequency is simply due to the grid size. In a simple 1D example, a grid of step h introduces the cut-off spatial frequency (Nyquist) kc= pi/h. It is dimensional since the frequency is expressed as
k = n*2*pi/L
this way you see that n is the wavenumber and k is the frequency. Be aware that if L=2*pi then k=n*(1). This means that n is always a number but, to be trasformed in a frequency k, that requires to be multiplied by 1 that has the dimension 1/L. Of course, this is never explicitly written and you can read in papers n or k.
bhigahAshish July 15, 2019 09:01
Hi, I have another question related to this. Is the cutoff related to the fact the we can considered the filter a top hat and doing the FT of a top hat function the first zero is at kc=pi/delta ??
FMDenaro July 15, 2019 09:40
No, the transfer function of the top-hat filter has an infinite number of zeros and is a function going to zero only for k->+Inf.
The the cut-off is due the superimposition of the grid size.
