Boundary conditions for streamfunction
Like Tree1Likes
Old   July 12, 2019, 10:40
Default Boundary conditions for streamfunction
E
IbizaFR is on a distinguished road
Hello to all,
I have written SIMPLE algorithm for 2D backwards facing step.
My problem is to calculate streamfunction from Poisson equation. In the attached figure are the boundary conditions used correct?
Thank you.
IbizaFR is offline   Reply With Quote
Old   July 12, 2019, 12:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by IbizaFR View Post
Hello to all,
Thank you.
Yes, they are mathematically correct. You can use a more physically free outflow condition by setting d2 psi /dy2 =0
FMDenaro is offline   Reply With Quote
Old   July 12, 2019, 14:30
E
Thank you.
With these boundary conditions i am solving a poisson equation but the resulting contours of calculated psi do not present the vortex near the bottom of step.
Old   July 12, 2019, 14:31
Thank you.
Maybe you need to check the vorticity field. What is the Re number?
Old   July 12, 2019, 14:37
E
The velocity field is correct compared to other works.
The code for vorticity field is the same for the lid driven cavity in which the streamlines are compared good enough with other works. The same code for cavity I copied to facing step but it does not give correct results.
Any help?
Old   July 12, 2019, 14:38
E
Any help?
Re=83-167-333.
Old   July 12, 2019, 15:22
Re=83-167-333.
Post the three solutions at a convergence state. Have you considered that to see the recirculating region you should plot the streamlines with negative values?
Old   July 12, 2019, 15:56
E
Yes when I have prepared the diagrams I will post them.
Thank you.
Old   July 13, 2019, 13:10
E
I post the dimensionless velocity and the dimensionless streamfunction field for Re=83-167-333. The resulting streamfunction results obtained from the poisson equation for the calcalation of Psi does not have any negative values at the recirculating region near the bottom of the step. The poisson equation is solved with either ADI or Jacobi technique.
Thank you.
Old   July 13, 2019, 13:11
E
Also the velocities for Re=333.
Old   July 13, 2019, 14:09
From the figures the solutions seem obtained from a irrotational field. Check vorticity and convergence criteria
Old   July 15, 2019, 12:41
E
I corrected the poisson equation for the calculation and I attach the streamlines for Re=8.3-10-50-83-100-167-200-250-300.
Are they in a way correct?
Thank you.
Old   July 15, 2019, 12:43
E
I also post the results for Re=167-200-250-300.
Old   July 15, 2019, 14:58
The results show a better solution but something is still wrong. The recirculation region extends through the outflow. I suggest to extend the domain lenght and verify your reattachment lenght with the results in literature cited here
https://www.researchgate.net/publica...ical_procedure
Old   July 15, 2019, 15:42
E
I will check it. The reattachment length is the line where the vorticity is zero?
Old   July 15, 2019, 15:59
The first point on the bottom wall where the vorticity is zero
Old   July 15, 2019, 16:09
E
Thank you.
Old   July 15, 2019, 16:12
Thank you.
However, check for bugs in the code, as you can see from the figures the streamlines from the inflow are quite strange
Old   July 15, 2019, 16:20
adrin
adrin is on a distinguished road
Curious, what was wrong with your poisson solver? If the code worked for the cavity flow it would mean your poisson solver is correct - except, of course, for the boundary condition.
Also, would you be able to share the algorithm you use for solving the vorticity transport equation?
adrin
adrin is offline   Reply With Quote
Old   July 15, 2019, 16:30
E
adrin
It was an error in boundary conditions for streamfunction for the step. Iterative solvers for poisson equations can be applied.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
