September 10, 2019, 14:17 |
Fully developed flow and convergance
Soumitra Vadnerkar
Rep Power: 7 |
What is connection between a fully developed flow and its convergence?
Can I say, in case of simple flow through pipe scenario, a converged steady state solution would always yield a fully developed flow at the outlet? Also do you think the attached image of velocity contour can represent a fully developed flow till the time it reaches the outlet? https://postimg.cc/Dmf1r3hb |
September 10, 2019, 15:33 |
#2 | |
Alex
Rep Power: 46 |
So if the computational domain is not long enough for the flow to be fully developed, you won't get a fully developed flow at the outlet, no matter how good the numerical convergence is. Unless of course you prescribed fully developed conditions at the inlet The easy way to ensure a fully developed flow would be periodic boundary conditions. |
September 11, 2019, 09:23 |
Rep Power: 11 |
"Fully developed" is a property of a physical flow at hand while "convergence" is a property of a numerical solution. The two have literally nothing to do with each other.
September 11, 2019, 09:50 |
Soumitra Vadnerkar
Rep Power: 7 |
Yeah but, I thought that as velocity profile does not change further, it might be helping for convergence.
convergance, fully developed flow, velocity profile |
K Epsilon convergance issue | Ollie | OpenFOAM | 2 | April 18, 2011 08:28 |
Inviscid Flow Convergance issues | FormulaRacer | Siemens | 1 | November 19, 2010 14:18 |
Free Surface Problem - Convergance | Toby | FLUENT | 0 | July 2, 2008 23:16 |
Second order convergance. | Rob | FLUENT | 2 | July 20, 2004 10:49 |
mass convergance | subhash | Siemens | 2 | September 9, 2002 01:14 |
