Solution diverges at high Reynolds numbers and fine grid in COMSOL |
Rep Power: 5 ![]() |
Hi, I'm using COMSOL to simulate heat transfer of a flow over a series of cylinders.
When I use Reynolds numbers bigger than 100, the solution only converges with normal mesh and it diverges with finer meshes! It diverges with following grid at Re=200 and converges with Re=100! ![]() And It will be converged with this grid: ![]() And it makes me unable to check mesh dependency. Is there any reason? |
comsol |
Display Modes | |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 90 | October 3, 2019 08:01 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 04:58 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
On grid independent solution for pulsatile flow | David | FLUENT | 4 | June 8, 2005 17:20 |
