pressure loss in presence of conjugate heat transfer in internal flows
Old   September 2, 2019, 09:32
Default pressure loss in presence of conjugate heat transfer in internal flows
nima103 is on a distinguished road
Hi Eeryone,
I am trying to calculate presssure loss of a flow in a pipe while the flow is being heated. I would not use the Darcy-Weisbach equation in presence of heat transfer because the quantity of heat being introduced into the system is not negligble.
Can anybody give me an idea where can I begin to make an analytical/numerical model?
nima103 is offline   Reply With Quote
Old   September 5, 2019, 14:03
Lucky Tran
LuckyTran has a spectacular aura aboutLuckyTran has a spectacular aura about
There aren't analytical solutions for arbitrary heat transfer quantities unless you can constrain the process in some way to exploit some characteristics.
Consider the Darcy-Weisbach not in the discrete sense, but in differential sense.
Discrete form:
\frac{\Delta P}{L}=f\frac{\rho}{2}\frac{U^2}{D}
Differential form
\frac{dP}{dx}=f\frac{\rho}{2}\frac{U^2}{D}
This is now an ordinary differential equation that you can integrate numerically provided you have addition equations of state to get density and velocity along x and the friction factor f being a known property of the flow (dependent only on Reynolds number). Keep in mind of course that the Darcy-Weisbach relation is an empirical relation and doesn't work for all flow scenarios. At the end of the day, it is a model.
You can also integrate the discrete case as well (it artificially looks like you would treat the pipe as a bunch of successive segments with constant densities). This seems theoretically not sound to people not familiar with discrete calculus, so I like to show people this way via an ode how it would work.
Conjugate heat transfer problems - Temperature Divergence KevinZ09 FLUENT 6 March 6, 2018 04:32
Significance of Turbulence parameters on Heat transfer and Pressure Loss Inderjeet Singh FLUENT 3 February 24, 2017 20:01
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 04:43
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
