September 30, 2019, 07:53 |
Operating Pressure and Gauge pressure
Yup
Hi guys, I am trying to simulate nozzle flow conditions. I have a doubt regarding boundary conditions setup. If I want my far side domain outlet as pressure outlet set at atmospheric pressure. Then should I set my gauge pressure at 101325 while my operating pressure is set to 0? Or should I try with operating pressure set as 101325 and gauge pressure set to zero? Which one is correct and what is the difference between the two?
September 30, 2019, 10:14 |
Lucky
Rep Power: 65 |
In general, both will work.
Having a non-zero operating pressure helps for machine precision (which isn't usually any issue nowadays). Some models specifically require a specific value for the operating pressure: some combustion models, some natural convection models, etc... Last edited by LuckyTran; September 30, 2019 at 12:54. |
September 30, 2019, 10:31 |
K-omega
Yup
I am using K-omega with SST model. For this model, are there any specific requirements?
September 30, 2019, 12:55 |
Lucky
Rep Power: 65 |
Nothing special. Just use whatever combination is most aesthetically pleasing to you or helps you interpret the results more reasily.
October 1, 2019, 08:04 |
It depends from case to case, but doesn't depend from the turbulence model.
If most of your domain is around 101325 but you use 0 as reference, you are wasting 6 orders of magnitude in the pressure precision, i.e., you can see pressure differences only of order 1e-9/1e-10 instead of 1e-15/1e-16. If this matters or not depends from case to case. Of course, it is mandatory to get it right in single precision |
ansys 19.2, boundary condition, pressure out |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
doubts in operating and gauge pressure setting | sanjiiv | FLUENT | 4 | May 28, 2016 02:03 |
Gauge pressure in 'Pressure outlet' boundary conditions, if operating pressure given | anilprajapati607 | FLUENT | 3 | April 13, 2016 13:17 |
Understanding Operating Pressure | yow | FLUENT | 3 | July 20, 2015 22:31 |
Gauge or operating pressure ? | guido_88 | FLUENT | 5 | December 5, 2009 12:54 |
