Boussinesq approximation
I am solving High Rayleigh natural convection problem ( air in square cavity whose vertical sides are heated and horizontal ones are adiabatic )
so do i consider gas an ideal gas or use Boussinesq approximation? when Boussinesq approximation is used? thank you |
Hey Tahtawy.
In the Boussinesq approximation you consider the density function of the static temperature, also if normally it depends also on the pressure and the velocity. So, if in your simulation there are small variations in pressure and small velocity, you can use the Boussinesq approximation. Otherwise, no. Cheers, Carlo |
This model can be applied for small temperature difference |
my case is 40 degree difference |
will bousinessq here will aid in converging the residual ? |
The approximation is based on a linear expansion. Just valid for few degree of variation, 40 is too much |
Uhm...I don't agree to much..CFX Tutorial use this approxiamtion with a 70 degree of difference..
https://www.sciencedirect.com/scienc...1793101300820X |
Hey FMDenaro, thanks to post that article!
Uhm..so maybe the CFX tutorials are not so trustable.. Thanks again, Cheers, Carlo |
Its only valid for the air, for other fluids, it depends on the expansion factor at constant pressure. For example the error is much bigger for the water. |
