September 26, 2019, 04:43 |
scaling a mesh generated by gmsh
Mehdi Baba Mehdi
Rep Power: 15 |
I want to scale a grid generated by gmsh to use in OpenFoam, but using
gmshToFoam -help |
September 26, 2019, 10:37 |
Mehdi Baba Mehdi
Rep Power: 15 |
The problem arises from convering geo file to msh file with version 4. it should be done instead with version 2.
September 27, 2019, 12:38 |
Lucky
Rep Power: 65 |
By the way there is an OpenFOAM utility for scaling a mesh, e.g.
transformPoints -scale "(1 1 1)" You can use this after you convert the mesh to foam. |
gmsh 4.0.4, gmshtofoam, openfaom-5 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
SU2_CFD 3d euler not converge mine gmsh mesh | lpustin | SU2 | 2 | December 3, 2017 13:43 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ANSYS Meshing] Scale geometry but mesh size to remain same | sangrampp | ANSYS Meshing & Geometry | 1 | February 12, 2016 05:19 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
