October 16, 2019, 04:28 |
Supersonic Freestream
Rep Power: 8 |
Hello everyone,
I wonder if there are any analytical methods to estimate the angle of a supersonic free stream e. g. out of a pipe with given p, T and Ma inside the pipe. Does anyone know if there is a possibility? Unfortunately I cant find one. |
October 18, 2019, 04:45 |
Rep Power: 8 |
I am a bit confused by this reply.
October 18, 2019, 15:36 |
Rep Power: 18 |
I think you got hit by a spam reply. Regarding your question, it is somewhat ill-posed. Flow won't just go supersonic inside a pipe, and how the flow reaches the state it possesses at the exit may play a role in further analysis.
But assuming that the flow is supersonic at a duct exit you have three cases to consider. First, the exit pressure at the duct matches the pressure of the atmosphere. In this case the jet should leave fairly smoothly since there will be no need for compression or expansion. There will be a strong shear layer between the jet and the freestream that will go unsteady. If the pressure at the duct exit is less than the freestream you may get a normal shock at the duct exit that will jump the pressure up to freestream, and the flow will effectively leave the duct subsonically. If the pressure difference is not too large the pressure adjustment may occur through oblique shocks and expansions that will work to correct the pressure and adjust the velocity angles. If the pressure in the duct is higher than the freestream, the flow will continue to expand upon exit through a series of expansion fans and possible weak oblique shocks. The classic example of these behaviors is the converging-diverging nozzle operation. I suggest you look there and see where that leads you. |
October 21, 2019, 03:29 |
Rep Power: 8 |
Thanks for your reply!
I know all that about the nozzle. The stream inside the pipe is subsonic and then reaches Ma = 1 in the narrowest cross section, where is also the end of the pipe. After that the stream leaves the pipe while expanding (Prandtl-Meyer Expansion). I want to know if there is a possibility to determine the angle of the outflow for e.g. given pressure ratios without using CFD. |
October 21, 2019, 10:23 |
Rep Power: 18 |
You might find something through the method of characteristics.
October 21, 2019, 11:16 |
#6 | |
Filippo Maria Denaro
Rep Power: 71 |
Have a look to the textbook of Zucrow |
Supersonic outlet working | saisanthoshm88 | CFX | 1 | November 15, 2015 18:43 |
[How to obtain supersonic flow inside a supersonic wind tunnel ?] | yx213 | Siemens | 1 | September 17, 2014 13:52 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 04:55 |
Probelm with supersonic exhaust to ambient | newj | CFX | 2 | August 9, 2012 18:01 |
mesh generation for supersonic flow followed by freestream | padmanathan | FLUENT | 6 | September 14, 2010 07:53 |
