December 12, 2019, 03:57 |
Eccentric VS concentric
Rep Power: 6 |
In an annular flow where we have two pipes (or two cylinders), eccentricity results in a higher flow rate values under the same pressure gradients compared to the concentric case (whatever the fluid rheology is). I want to know why (or how) does eccentricity increase flow rate? Last edited by Belimane; December 12, 2019 at 07:47. |
December 12, 2019, 09:44 |
Lucky
Rep Power: 65 |
Consider delivering a volume of flow through one single large pipe versus two smaller pipes. One bigger pipe is better.
The reason has a lot to do with dynamic head being the square of velocity plus a tiny contribution due to friction factor dependence on Reynolds number. Consider an intermediate case where there are still two pipes, but one is larger than the other. For the same dynamic head, the velocity is smaller in the smaller pipe (which can be counter-intuitive). One might think that for the same head, the velocity is higher in the smaller pipe due to Bernoulli's principle. |
December 12, 2019, 10:13 |
#3 | |
Rep Power: 6 |
Although ... i didn't really understand your explanation. To make my question more clear, i am adding this picture.[ATTACH] |
December 12, 2019, 10:22 |
Lucky
Rep Power: 65 |
The eccentric pipe splits the flow into a smaller area and large area. It's like having two equally sized pipes, and then making one bigger and one smaller.
[GAMBIT] Concentric and Eccentric | Heat Pipe | ANSYS Meshing & Geometry | 4 | February 4, 2020 00:16 |
How can calculate torque of eccentric moving axis and eccentric surface velocity | Fahd | CFX | 0 | January 9, 2018 03:28 |
Problem with building geometry - concentric cylinders | Rhoddwen | OpenFOAM Pre-Processing | 9 | December 17, 2014 10:02 |
[GAMBIT] 3D Concentric and Eccentric Annuli | Heat Pipe | ANSYS Meshing & Geometry | 1 | February 25, 2014 01:24 |
Problem with Eccentric pipe annulus..Pls Help me | Parag Ramteke | FLUENT | 2 | April 4, 2005 06:34 |
