Stream function - vorticity boundary conditions for Couette flow |
December 13, 2019, 15:04 |
Rep Power: 8 |
I want to solve Couette flow without pressure gradient using stream function - vorticity formulation. I need two boundary conditions for each plate. I know that velocity and stream function values are zero on lower plate. Also, for the upper plate, the derivative of stream function equals to the velocity (U). I need one more boundary condition. Which boundary condition should I use for the upper moving plate? |
December 13, 2019, 15:10 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
You have the BCs for the vorticity on the upper wall, it is just du/dy at the wall. |
December 13, 2019, 18:33 |
Rep Power: 8 |
December 14, 2019, 03:05 |
Rep Power: 71 |
December 14, 2019, 03:22 |
Rep Power: 8 |
December 14, 2019, 04:05 |
Rep Power: 71 |
yes, that's from u = dpsi/dy
psi(y)-psi(0)= Int[0,y] u dy = (Uw/h) Int[0,y] y dy psi(y)=psi(0) + (Uw/h)*y^2/2 Are you using periodic condition in x? |
December 18, 2019, 12:54 |
Rep Power: 8 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Simple stream function vorticity formulation for flow past a rectangle [Matlab] | a99 | CFD Freelancers | 0 | March 1, 2016 21:36 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
