Pressure coefficient plot for rotating problems |
January 10, 2020, 08:58 |
Adrian P.
Rep Power: 6 |
Hi there!
I have a quite trivial question guys - if I have a simple rotating flow with pressure-inlet and pressure-outlet BCs, where the flow is only driven by the rotation of the impeller, how can I plot the Pressure coefficient value? As the denominator says(1/2*ro*Uinf^2) I need the value of the infinity's velocity but hey, there is no such velocity because I don't have velocity-inlet, so what value should I put as Uinf ? Thanks a lot Adrian |
January 10, 2020, 11:00 |
Rep Power: 18 |
Typically a velocity is constructed from the rotational speed and a characteristic length - for example, use W*R, where W is the angular velocity of the driver, and R is the radius (assuming this is some type of impeller disk or such thing). If you have access to any literature in the area you are working in, you should be able to find some standard type definitions.
January 13, 2020, 01:55 |
Adrian P.
Rep Power: 6 |
Thank you for your advice, that is kind of working for now but I will keep an eye on this topic and look for insights.
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
How can I plot the pressure coefficient vs angle? | ck3 | FLUENT | 4 | February 4, 2016 06:01 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
