Problem in exporting file from BladeGen to TurboGrid
Old   January 16, 2020, 13:54
Default Problem in exporting file from BladeGen to TurboGrid
Dushyant Singh
Dushyant is on a distinguished road
I am trying to run simulation on a Radial Turbine Blade created in BladeGen. But when I try to transfer the data in TurboGrid Mesh it gives an error that says " Error Occured while writing .inf file". I tried generating the .inf file in BladeGen but whenever I do so it says that the application has stopped working. The three .curve file are being created but the .inf file seems to have some problem. Please help.
Dushyant is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 77 May 7, 2020 04:22
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
Custom Thermophysical Properties wsmith02 OpenFOAM 3 July 27, 2015 05:37
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
