connection between the step-sizes and numerical-speed
Old   January 21, 2020, 09:00
Default connection between the step-sizes and numerical-speed
Prabhat Mishra
Prabhat Mishra is on a distinguished road
Is there any connection between the step-size and the wave speed ?
for example, we have hyperbolic conservation equation u_t+f(u)_x=0, If we write it's numerical scheme for non-uniform (2p+1) points then how we will write the expression for f'(u) for non-uniform mesh ? I would also like to know of some references regarding this.
Prabhat Mishra is offline   Reply With Quote
Old   January 21, 2020, 11:38
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Not clear to me why do you define "numerical" a term that appears in the PDE ... Could you detail better you question? Is that focused on hyperbolic equations?
FMDenaro is offline   Reply With Quote
Old   January 21, 2020, 13:23
Prabhat Mishra
Yes Sir, the question is based on the hyperbolic equation. In the case of uniform mesh the finite difference scheme under consideration are of (2p+1) points in conservative form,
v_j^{n+1}=H(v_{j-p}^n, ... , v_{j+p}^n):=v_j^n-k/h [F(v_{j-p+1}, ... , v_{j+p}^n) - F(v_{j-p}^n, ... ,v_{j+p-1})].
The expression for a(u) is mentioned in Page No. (303) of the given Reference.
Reference: A. Harten, J. M. Hyman and P. D. Lax: On Finite Difference Approximation and Entropy Conditions for shocks
How we will write the expression for wave- speed a(u) for non-uniform mesh-points ?
Old   January 21, 2020, 19:08
One of the best textbook I can address is Leveque, Finite Volume for Hyperbolic Problems.
In a conservative method you do not write the equation in a quasi linear form, that is you evaluate the flux f(u) not the term df/du*du/dx
Why decreasing time step makes diffusion more significant for diffusion equation? TurbJet Main CFD Forum 30 February 18, 2018 04:45
