February 8, 2020, 11:58 |
Flow Phenomena in Nozzle
Rep Power: 6 |
I simulated a nozzle I created using method of characteristics at mach 6.13. The nozzle is simulated with SU2. I am getting a strange flow phenomena I don't think should be there. The boundary layer appears to be relatively large (x and y are in meters). I have attached a photo. Would this be a result of numerical error?
February 8, 2020, 13:36 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
I don't know what SU2 solves in your problem. You should better clarify what you are doing. Is that a characteristic method applied for Euler equation ? In the case of omo-entropic expansion you can use the Riemann invariant to develop the exact solution and there is no physical boundary layer. |
February 8, 2020, 14:26 |
Rep Power: 6 |
I am doing a RANS calculation using SST to solve my boundary layer. The inlet is defined by the freestream values (calculated with isentropic relations) with a supersonic outlet. The inlet is slightly after the sonic point, so Mach no. is around 1.03 to start.
February 8, 2020, 15:15 |
#4 | |
Rep Power: 71 |
Ok, now it is clear to me, you have first developed the geometry using the Euler equation and the characteristic method, then you are using such geometry to solve a real viscous turbulent flow. I suppose you are working at a very high Re number, are you using a grid so fine to resolve the BL until the laminar sublayer? Clearly the geometry designed for inviscid isoentropic flow does not ensure that the BL is fully attached to the wall, the case you are simulating is quite challenging. I have no direct experience on this case at high Mach number, I suggest to check the grid resolution near the wall, I suggest also to try some different turbulence model to see the differences. What is more, I suggest to try replicate a case where data are available in literature. You should post also the 1D velocity profiles along some stations in streamwise direction |
February 10, 2020, 09:44 |
Rep Power: 6 |
I have done a RANS simulation successfully of existing nozzles, but not with hypersonics (Mach no. was around 2 and 3.5). The spacing at the wall is not the issue according to my y+ value. I checked the vector field of the velocity, and it looks like a boundary layer. I am hoping that changing the boundary conditions to Reimann BC's will mitigate this issue.
boundary layer, su2 |
Issues when simulating nozzle flow with outside region | blais.bruno | SU2 | 4 | March 13, 2024 14:04 |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Having Problem solving 2D supersonic flow around a plug nozzle | chrislloyd | FLUENT | 7 | July 22, 2015 13:09 |
calculate a nozzle flow using rhoCentralFoam | hg2lf | OpenFOAM | 0 | October 25, 2012 21:26 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
