February 9, 2020, 10:01 |
Strouhal number for 3D bluff body
Rep Power: 7 |
Hi, It is very simple question but I have a problem. I am trying to find Strouhal number(St= fD/u) for 3D cylinder. I used Ansys Fluent for simulation. until it was a periodic wake, I calculated Strouhal number by two ways (i) read data for cylinder and and check its period time manually.
(ii) Strouhal number by using Fluent built in function. Values I found by these techniques have much difference. Why is there difference in these values? How could I solve this problem. Is there any other way I could find accurate Strouhal number. I need to solve it for my project. Please let me know! Last edited by esha; February 10, 2020 at 08:33. |
February 9, 2020, 12:58 |
Alex
Rep Power: 46 |
I have no idea what happens behind the curtain when you let Fluent determine a Strouhal number. But I guess that it uses reference length and velocity from the reference values tab. So make sure to enter values that match your simulation settings. And you probably need to ensure that only results after the initial transient are used.
A third method could be to monitor lift forces for the cylinder, and apply FFT to the signal. |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 22:29 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
Stable boundaries | marcoymarc | CFX | 33 | March 13, 2013 06:39 |
