February 27, 2020, 07:31 |
CFD validation of wind tunnel data.
Francois
Rep Power: 6 |
Hello.
I am in the process of validating a 2D airfoil CFD simulation against given wind tunnel data. I get good polars for comparison, but I know I am not using the correct setup. The paper gives Re = 1e6, Ma = 0.1 and turbulence intensity of the wind tunnel = 0.05% at 46m/s. For my simulation I just used the Re number and the default density and viscosity to calculate the flow velocity as 15.67[m/s]. My questions are: - How do I calculate the turbulence intensity for my simulation? I have an equation I = sqrt{(3/2)*(Vt^2)/(U^2)} can I use this to calculate the turbulent velocity scale (Vt) at velocity (U) of 46[m/s], and turbulence intensity (I) of 0.0005. Then v=with the velocity scale known calculate the turbulence intensity at simulation velocity? Or does the velocity scale vary with the velocity? - Is the Ma number important when I calculate my flow conditions in the simulation? I am having trouble finding references for these questions I have. |
February 27, 2020, 12:16 |
Lucky
Rep Power: 65 |
It's better to use the same turbulence intensity in your simulation as from the experiment.
Vt is a property of the flow and depends on pretty much everything. Anything that can affect the flow will affect Vt. The inlet Mach number tells you how much compressibility is already in the inlet flow. It's rather minor compared to the Reynolds number. The purpose of validating is to find answers to these questions. If the answers were already available, you wouldn't be validating in the first place. |
February 27, 2020, 13:05 |
Francois
Rep Power: 6 |
Thank you. So I can use 0.05%, even though I will be running the simulation at a much lower velocity as the TI reference velocity of 46[m/s]?
February 27, 2020, 13:52 |
Filippo Maria Denaro
Rep Power: 71 |
"- Is the Ma number important when I calculate my flow conditions in the simulation?"
Your inlet Ma number is enough low to assume a full incompressible flow model. I would exclude that around the airfoil the increasing in the local Mach number (I think it can't reach more than 0.3) would produce relevant compressibility effects. |
February 27, 2020, 14:02 |
#5 | |
Lucky
Rep Power: 65 |
Turbulence intensity is like Reynolds number and Mach number. If you understand why it is important to match Reynolds number and Mach number, the same holds for turbulence intensity. You can run a completely different velocity, density, and viscosity as long as Re is the same. Turbulence intensity is kind of the same way. |
February 27, 2020, 14:07 |
Francois
Rep Power: 6 |
Thank you for the replies. I now have a much better understanding of how to proceed with my study. I really appreciate it.
cfd, turbulent intensity, validation, wind tunnel |
Help: CFD Validation for Formula One Halo | AndreP | STAR-CCM+ | 16 | August 15, 2018 14:32 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
CFD Model of a Small Open Jet Wind Tunnel | rfar0028 | FLUENT | 0 | November 21, 2011 06:11 |
Relation Between Wind Tunnel and CFD | dido | Main CFD Forum | 5 | March 4, 2011 18:18 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
