Define interface between two non conformal meshes |
February 27, 2020, 04:57 |
Amr Emad Ezzat
Rep Power: 6 |
Hello everyone,
Does anybody have any idea about how to define an interface between non-conformal meshes (e.g Tetra and Hexa) without moving the interface in OpenFOAM? Thanks in advance! |
February 27, 2020, 10:35 |
Mikko
Rep Power: 12 |
Hi Amr,
If the interfaces are adjacent, you can use arbitrary mesh interpolation (AMI). If the meshes are overlapping then use overset. If you want to make the two meshes conforming, you can either add hanging nodes or a layer of pyramids at the interface. Best, Mikko |
February 27, 2020, 10:39 |
Amr Emad Ezzat
Rep Power: 6 |
Hello Mikko,
Perfect. Is this fit the cyclicAMI type or there is another type to be used? knowing that the two sides of the mesh are static and not moving |
interface domains, mesh 3d, non conformal interface, openfoam |
Display Modes | |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
An odd ERROR | mdakbari | Fluent UDF and Scheme Programming | 7 | April 4, 2016 05:30 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
UDF FOR UNSTEADY TIME STEP | mayur | FLUENT | 3 | August 9, 2006 11:19 |
