OpenFOAM1912: save only plane &surfaces
Old   March 23, 2020, 19:15
Default OpenFOAM1912: save only plane &surfaces
Marcelo Italo Adotti
italoadotti is on a distinguished road
Hi foamers,
I need to save just a few planes and surfaces for a simulation, with the overPimpleDyMFoam solver.
Now I run in parallel with 16 processors and generate about 150GB of results, but it is too big it can only run 0.0 ... 2 seconds.
Can anyone recommend a solution or a link to read?
Thank you.-
italoadotti is offline   Reply With Quote
Old   March 24, 2020, 01:21
Lucky
I don't use the latest FOAM so I can't dump any links but Foam comes with a sampling utility that allows you to output surface data at runtime. You just need to put the right stuff in your controlDict and link libsampling.so
There is also postProcess utility that also has similar features but is meant to be run after a simulation has finished. If your case is already done and you are just trying to extract the results needed and recover some hard disk space, this is the way to go.
Old   March 24, 2020, 16:42
Hey Lucky Tran,
Thanks for your advice, but my idea was not do a postProcces actually i do likewise you explainme. I need a solution to minimize the size of data, during the running.
functionobject, openfoam1912, sample, surfaces
OpenFOAM error Vinay Kumar V Main CFD Forum 0 February 20, 2020 09:17
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Save data only from a plane Pj. OpenFOAM Running, Solving & CFD 3 May 22, 2013 06:21
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Transient data save in plane Vadims.geza OpenFOAM 2 April 14, 2010 06:15
