March 29, 2020, 12:10 |
[LES] Reynolds stress(w'w') is lower than DNS
Rep Power: 8 |
I simulated a duct flow using Dynamic Smagorinsky model. The simulation is completely converged. The <w'w'> component of Reynlods stress is about half of DNS (you can see it in the attached image) while the mean streamwise velocity profile has a good agreement with DNS. Anyone knows why? Thank you. Last edited by Moreza7; March 29, 2020 at 16:15. |
March 29, 2020, 13:29 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
How did you compute the RMS? |
March 29, 2020, 16:07 |
Rep Power: 8 |
March 29, 2020, 16:33 |
Rep Power: 71 |
I suggest to check further your RMS. The comparisons we did showed Code_Saturne overestimates the DNS peaks for the plane channel flow, see
https://www.researchgate.net/publica...mulation_codes maybe the statistically averaged velocity is not well computed |
March 29, 2020, 23:51 |
EM
Rep Power: 6 |
Give some bleeding info about your simulation and that u are comparing with.
Document yr flow before you ask a question. what Re? what resolution? whose dns? what is the exact geometry, channel or rec/sq duct? which is the wall-normal and wall parallel component? if duct, where in the cross section are the profiles from? are u including an estimate of the sgs intensity in the stats? show a comparison with all three intensities. -- |
large eddy simulation |
Reynolds Stresses | mechkween | OpenFOAM | 0 | June 20, 2017 20:58 |
what are reynolds stresses | UnderGroundMan | Main CFD Forum | 0 | November 7, 2008 13:49 |
Reynolds stresses without velocity correlations? | Phil | Main CFD Forum | 1 | October 2, 2006 04:29 |
Reynolds stresses and second law | JF | Main CFD Forum | 6 | June 2, 2005 22:57 |
DNS -low Reynolds number Airfoils | Pat | Main CFD Forum | 2 | January 21, 2005 14:17 |
