April 12, 2020, 06:55 |
Comparison of RKE and SST model
Rep Power: 6 |
After performing some simulations with both RKE and SST k-w models, some conclusions appeared, but i failed to give good explanations for these. The Realizable k-epsilon (RKE) fails to predict separation, and leads to an overattached flow. I know something is overpredicted in this model and leads to this behavior, I just did not found what. Is there someone knowing what is overpredicted in the RKE model that would lead to this overattached behavior ? Also, the SST k-w did the opposite, predicting too much separation of the flow. The question here may be obvious for you but is not for me, why a stronger separation prediction is a bad thing ? Thanks in advance for those who will try to answer my questions. Regards, |
April 14, 2020, 04:52 |
#2 | |
Lucky
Rep Power: 65 |
You're probably thinking of the production of k term. |
rke, sst k-omega |
Display Modes | |
Turbulence Model switch RKE to K-omega SST | Astan | OpenFOAM Running, Solving & CFD | 3 | April 6, 2019 04:54 |
turbulence model for separated flow in diffuser | Martis | STAR-CCM+ | 0 | March 2, 2010 03:08 |
