k-w SST and Wall functions: How many layers? (Automotive aerodynamics) |
April 17, 2020, 10:21 |
Andrea Stedile
Rep Power: 6 |
Greetings,
I am using the OpenFOAM CFD suite to study the aerodynamic forces that act on a vehicle (more precisely, an Ahmed body). I chose the k-w SST model, with wall functions boundary conditions. I am still a beginner, and unfortunately I have no background in CFD. Right now, I am able to create some simple but fine meshes (with some millions of cells). I taught myself how to add layers on the vehicle's surface mesh and check the y+ values after the solver has run. I usually reach ~ 98 / 99 % of layer thickness. However, I do not understand: How many layers should the vehicle's surface have? I noticed that y+ somewhat depends on the size of the first layer. On the Internet, I saw that, when using Wall functions, y+ should be between 30 and 200 (or 30 and 300); whereas, when using a "full resolution" approach, y+ should be <= 1. I also saw that, with the full resolution approach, the required number of layers should be 10, 20, or even more. In my case, I am using wall functions, but I did not find a resource that points out the required number of layers. Do you have any idea? If this can help, the motorbike tutorial in OpenFOAM, which uses the same model and wall functions, uses just 1 layer. |
April 17, 2020, 17:01 |
Lucky
Rep Power: 65 |
It's like asking how many cells you should have in your mesh. The answer is, however many you need to get the answer that you need. That is, we can't tell you unless you have an objective in mind. Even still, there aren't hard rules.
Some people need to capture all the boundary layer development in their models and so they pack the boundary layer full of cells. You can do this with layers or you can even do it with regular cells. Some people don't care about the boundary layers. They might use very few layers just to have a nice mesh near surfaces so that you don't end up with velocity vectors pointing into walls. Some people don't even about this and will use no layers. Some people are just doing CFD for funsies, just for the colors and don't do any postprocessing, none of these settings matter for them. The scientific method applies. If you think it might change something, try it and find out. |
April 22, 2020, 13:42 |
#3 | |
duri
Rep Power: 16 |
In wall integration number of layers implies number of layers in viscous sub laminar usually y+ < 4. But in case of wall function no. of layers is not defined. The first cell should be in valid log law region typically y+ 30 to 200. It doesn't matter how many cells you have in log law region because shear stress is calculated from the log law and not from velocity gradient. |
aerodynamics, automotive, layers, mesh, wallfunction |
One more time: wall functions - SST | CellZone | OpenFOAM Pre-Processing | 22 | June 11, 2021 13:27 |
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 13:57 |
K-omega SST Wall functions | ajmwtt | FLUENT | 9 | March 26, 2019 09:39 |
k-Omega SST - Wall functions in OF 2.3 | shereez234 | OpenFOAM Running, Solving & CFD | 4 | November 12, 2015 02:54 |
